Hey guys
up for sale is my r33 gts non turbo skyline
shes very much a head turner and sounds very much like a turbo skyline
it stands our from the croud it been built very unique
car is a wraped by im wraped in liverpool
Car runs fantastic never had a problem
rims are powder coated orange there very unique
Car has coilovers very well looked after but im opening a bussiness so need the cash
so if intrested ethier mesage me or call me on 0420308540 or just message on the add and ill get back to u
https://www.sau.com.au/forums/topic/426547-r33-s1-93-model-na/
Where are you located an how much are you looking for? Auto or manual?
+1 where's the info? Km on car? Problems? And at Least a price. You really should read the forum rules before posting a for sale ad
