well
after all my stuffing around and damaged knuckles i cant get the fly wheel off - i am borrowing a firends impact driver air gun, but i still am stuck on locking the fly wheel - can anyone pm some help something visual if possible
thanks in advance
Where are you?
Locking the flywheel? Do you mean to hold the flywheel while you undo the bolts? I use $40 electric rattle gun (Dicksmith, Jaycar, Supercheap) to undo the bolts. If I don't have a rattle gun, I use a large screw driver on the wheel teeth, braced so it doesn't move.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884636
yeah thats what i am doing but keeps slipping - but i have a rattle gun coming this arvo hopefuly works -
i am more worried about doing it up (dont they need to be done up evenly 150nm)? guess that is the main time i need it to be locked - guess ill keep trying to lock it with different ways
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884706
When you do them up, put a socket on the crank bolt and brace against the body. Just do them up like a wheel, it's not super important like head work.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884913
Yes the ol socket on the harmonic balance locks it good.
And yes use a torque wrench to do it up properly, its real tight and you know you got it with the torque wrench.
If it comes off it can cut your legs off, so dont fk around.
Ps, i never got a flywheel off without a rattle gun.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885003
I AM WEAK LOL
No no no, its impossible without real good leverage while your jammed under there and can hardly move your arms let alone get a good strong push/pull.
Eiji is just very persistant, and had a very long breaker.
Dont forget to be super clean with the clutch, or it may slip.
Anyway, the hard bit is getting the box back on, that will test your patience. So be careful with the input shaft, its easy to bash it into the clutch plate or springs while trying to get it into position.
Doing the clutch up evenly takes ages too. But worth it.
Good luck, hope it goes smoothly.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885436
YEAH NPC told me to use some thinners or break cleaner on the clutch and or fly wheel surface to be clean as possible and clean the shaft and put very little amount of grease on the shaft..
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885477
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
