Reese69 Posted June 7, 2013 Share Posted June 7, 2013 hi guys i am proble pushing my luck but do you know anyone who is open tomorrow who could machine my fly wheel? i have tried ACT breakes and abs in fyshwick - anywhere else or should i just accept i have to wait till tuesday lol Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/ Share on other sites More sharing options...
Reese69 Posted June 7, 2013 Author Share Posted June 7, 2013 - admin pls delete - ( found one) Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6881909 Share on other sites More sharing options...
Sinista32 Posted June 7, 2013 Share Posted June 7, 2013 Phew - well done Reese (didn't have clue who could help at such short notice) Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6882170 Share on other sites More sharing options...
Got a Pulsar Posted June 7, 2013 Share Posted June 7, 2013 Still Don't. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6882198 Share on other sites More sharing options...
StinkyPoo Posted June 7, 2013 Share Posted June 7, 2013 lol, there are a few places. I pretty much went through the yellow pages until I found one that could do it on the day. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6882365 Share on other sites More sharing options...
Reese69 Posted June 7, 2013 Author Share Posted June 7, 2013 yeah phillip heads is going to do it in the morning - finish work at 10 tonight then home to pull clutch and fly wheel off - hopefully its in good condition and only needs an easy clean and light machine - Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6882396 Share on other sites More sharing options...
Reese69 Posted June 9, 2013 Author Share Posted June 9, 2013 well after all my stuffing around and damaged knuckles i cant get the fly wheel off - i am borrowing a firends impact driver air gun, but i still am stuck on locking the fly wheel - can anyone pm some help something visual if possible thanks in advance Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884447 Share on other sites More sharing options...
StinkyPoo Posted June 10, 2013 Share Posted June 10, 2013 well after all my stuffing around and damaged knuckles i cant get the fly wheel off - i am borrowing a firends impact driver air gun, but i still am stuck on locking the fly wheel - can anyone pm some help something visual if possible thanks in advance Where are you? Locking the flywheel? Do you mean to hold the flywheel while you undo the bolts? I use $40 electric rattle gun (Dicksmith, Jaycar, Supercheap) to undo the bolts. If I don't have a rattle gun, I use a large screw driver on the wheel teeth, braced so it doesn't move. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884636 Share on other sites More sharing options...
Reese69 Posted June 10, 2013 Author Share Posted June 10, 2013 yeah thats what i am doing but keeps slipping - but i have a rattle gun coming this arvo hopefuly works - i am more worried about doing it up (dont they need to be done up evenly 150nm)? guess that is the main time i need it to be locked - guess ill keep trying to lock it with different ways Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884706 Share on other sites More sharing options...
StinkyPoo Posted June 10, 2013 Share Posted June 10, 2013 yeah thats what i am doing but keeps slipping - but i have a rattle gun coming this arvo hopefuly works - i am more worried about doing it up (dont they need to be done up evenly 150nm)? guess that is the main time i need it to be locked - guess ill keep trying to lock it with different ways When you do them up, put a socket on the crank bolt and brace against the body. Just do them up like a wheel, it's not super important like head work. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884913 Share on other sites More sharing options...
D.I.Y. Mik Posted June 10, 2013 Share Posted June 10, 2013 Yes the ol socket on the harmonic balance locks it good. And yes use a torque wrench to do it up properly, its real tight and you know you got it with the torque wrench. If it comes off it can cut your legs off, so dont fk around. Ps, i never got a flywheel off without a rattle gun. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885003 Share on other sites More sharing options...
StinkyPoo Posted June 10, 2013 Share Posted June 10, 2013 Ps, i never got a flywheel off without a rattle gun. I have, used a loooooong breaker bar Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885321 Share on other sites More sharing options...
D.I.Y. Mik Posted June 10, 2013 Share Posted June 10, 2013 Yeah, it can be hard to get the room to swing them under there. But your like me.... dont give up easy. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885415 Share on other sites More sharing options...
Reese69 Posted June 10, 2013 Author Share Posted June 10, 2013 I AM WEAK LOL i think i might have it i had some advice with locking the crank but i was looking at it wrong so i think i will try it from the front.. rattle gun coming tonight.. thank you very much very much appreciated Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885418 Share on other sites More sharing options...
D.I.Y. Mik Posted June 10, 2013 Share Posted June 10, 2013 I AM WEAK LOL No no no, its impossible without real good leverage while your jammed under there and can hardly move your arms let alone get a good strong push/pull. Eiji is just very persistant, and had a very long breaker. Dont forget to be super clean with the clutch, or it may slip. Anyway, the hard bit is getting the box back on, that will test your patience. So be careful with the input shaft, its easy to bash it into the clutch plate or springs while trying to get it into position. Doing the clutch up evenly takes ages too. But worth it. Good luck, hope it goes smoothly. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885436 Share on other sites More sharing options...
Reese69 Posted June 10, 2013 Author Share Posted June 10, 2013 yeah gotta get past this point first.. i will ba haveing help with the box will be two of us holding and a 3rd guiding it then my mate can get his little fingers in there and do uo the starter motor bolts.. one step at a time Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885475 Share on other sites More sharing options...
Reese69 Posted June 10, 2013 Author Share Posted June 10, 2013 YEAH NPC told me to use some thinners or break cleaner on the clutch and or fly wheel surface to be clean as possible and clean the shaft and put very little amount of grease on the shaft.. No no no, its impossible without real good leverage while your jammed under there and can hardly move your arms let alone get a good strong push/pull. Eiji is just very persistant, and had a very long breaker. Dont forget to be super clean with the clutch, or it may slip. Anyway, the hard bit is getting the box back on, that will test your patience. So be careful with the input shaft, its easy to bash it into the clutch plate or springs while trying to get it into position. Doing the clutch up evenly takes ages too. But worth it. Good luck, hope it goes smoothly. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885477 Share on other sites More sharing options...
StinkyPoo Posted June 11, 2013 Share Posted June 11, 2013 I use something like this now:http://www.ebay.com.au/itm/NEW-UNIMAC-12v-Electric-1-2-Vehicle-Impact-Wrench-Car-ATV-Trailer-Tool-Sockets-/130802514213?pt=AU_Car_Parts_Accessories&hash=item1e746ff925 Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885762 Share on other sites More sharing options...
Reese69 Posted June 11, 2013 Author Share Posted June 11, 2013 mmmm interesting - thanks super cheap have one for the same price and simlar specs but run by air not elec.. but that one seems more versatile and usable anywhere - thanks Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885809 Share on other sites More sharing options...
StinkyPoo Posted June 11, 2013 Share Posted June 11, 2013 http://www.supercheapauto.com.au/online-store/products/Rockwell-Impact-Wrench-12v.aspx?pid=287228 I have one of these as well. The case split but you can still hold it together to use it. Link to comment https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885872 Share on other sites More sharing options...
