Ummm i recall seeing JET2NV or something like that selling one recently, google search it with SAU in the title and see how you go!
I have a Tial 1.06 stainless rear here, or have you checked Kando's housings? He sells some nice stainless T3 ones... Which I can't see around anymore...
Here is another style, 10cm rear.
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-Garrett-GT30R-GT3037-GT3076R-AR73-10cm-/290922121367?pt=AU_Car_Parts_Accessories&hash=item43bc4f4897&_uhb=1
    • Holy hell! That is absolutely stunning! Great work!!!
