I did some diagnosing recently using some found guides, but I found some more options and details worth mentioning and I intend to update this thread with images of the various sensors and actuators.
Hold OFF for 5 seconds within 10 seconds of turning ignition to ON.
1) A/C unit should light up all characters and lights with the exception of the backlight. In any diagnostic mode, the error codes (if any) will alternate. (e.g: 25/26/25/26/25/26/25/26/ etc)
2) Press UP for sensor check (2) and wait.
20 - No faults
21 - Outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (must be in sunlight to pass)
26 - Potential Ballast Resistor
27 - Refrigerant temperature sensor
3) Press UP for door-position check (3) and wait.
30 - No faults
31 - Face
32 - Face/Foot
34 - Foot
35 - Demist/Foot
36 - Demist
4) Press UP for manual actuator motion check (4) and wait. The fan motor show ramp up if it is working. Press the DEMISTER button to cycle through the following modes.
41 - Face
42 - Face/Foot - Recirculating
43 - Face/Foot - Fresh
44 - Foot
45 - Demist/Foot
46 - Demist
5) Press UP for temperature sensor check (5). Press the DEMISTER button to cycle through the following sensors.
- Outside temperature
- Inside temperature
Press the FAN button to adjust the sensor temperature + or - 3 degrees with the UP and DOWN buttons. The change is saved but the new temperature is not displayed in the diagnostics. This is good for fine-tuning, but settings will be lost if the unit is ever disconnected or the car battery is replaced.
To exit diagnostics, press AUTO.
Notes:
* If either of the temperature sensors are way off (e.g -25C), they might be disconnected or faulty. The inside sensor is
behind the grille in the dash where the antenna height button is. I have confirmed by spraying contact cleaner into it
while on diagnostics mode and it shot from 18C to 5C for a few minutes. I do not know where the outside sensor is.
* As mentioned above, if the sun-sensor is not in sunlight, it will throw off a "25" code which you can choose to ignore if
you are testing in the shade. It is a small round circle in the passenger-side demister vent about the size of a 10c coin.
It can be removed easily after the demister vents are popped out with a plastic prybar. Do the driver side first.
* If you are getting either hot or cold air no matter what you are selecting, it will most likely be the "26" actuator by
the drivers left foot. Its job is to mix between the heater core and regular air. It may move a little or not at all, but
for it to seal off from the regular air or heater core air, it needs to have a full range of motion. The unit can sometimes
be opened and fixed by bending one of the metal contacts back in place that tells the actuator when it has reached its
limits. I replaced mine with a new one. Three screws hold it to the aircon box, and the door-flap rod is connected with a
clip that requires a fair bit of force on a set of pliers to pop off.
* If you have a clicking sound on startup and MODE selections, it is a common fault with R33's probably due to age and
Australian heat and the proximity of the actuator to the surface of the dashboard. This actuator is known to eventually
break teeth off one of the internal gears as uses some teeth more frequently than others for daily operation. There are
guides on opening these units and rotating the gear 180 degrees so that it uses teeth that are previously unused and in
good condition. Opening the unit is very difficult and I was not able to do it.
That's the easy part, getting to the unit is almost impossible with a Series 2 with airbags unless you partially remove the
dashboard. There are guides for series 1 whereby you can reach it by hand after removing the glovebox (5 minute job) and
some claim to have swapped it successfully in an airbagged series 2 by shifting the fan motor and airbox, but I tried this
and could barely even touch the actuator, much less get a socket on the two bolts holding it in. I replaced it with a new
item after partially removing the dashboard. Getting to the point of removing the dashboard takes me about an hour, perhaps
less, and once at that point, I could lift the dashboard up 10 inches or so... enough to get two hands and a ratchet in
there to remove the actuator easily.
My "26" Air Mix actuator and a replacement part.
https://www.sau.com.au/forums/topic/426605-aircon-diagnostics-r33/
27730M (up under the dashboard)
277??? (driver footwell) Potential Ballast Resistor opened up. Arcing occurs due to weakened/worn metal contacts and rough roads. Mine arced to the point it broke the track and ate halfway through the PCB.
  • 1 month later...
awesome post mate! stumbled across this when I was trying to find how to stop the dreaded a/c clicking noise - or more descriptive, a way to get to the actuator in a s2 with the airbag. For the life of me I couldn't even get my hands in there to touch the unit, let alone remove it. I've even got the missus to try (way smaller hands then mine) and whilst she can touch the unit and almost get to the first bold, no joy.... nothing to show for it, but lots of small cuts.
I like your idea of only partially removing the dash (I feared my only solution was a full dash removal) and i've just scanned through predators full dash removal guide. (Link here) and found some photos that were still working (Link Here)
I'm wondering just how far into the dash removal you had to go, to be able to lift it up 10cm or so?
or if since you wrote this post, you may have had another idea on how to get to the actuator? - i'm really not keen on removing the entire dash or doing 98% of the dash removal, with the remaining 2% being the difference between taking the dash out of the car or not?
Any ideas/info you could provide would be greatly appreciated! Anything to save me from either ripping out the entire dash, or slicing my hands to pieces :laugh:
Cheers
Adam
Hey mate! Thanks for the feedback!
I think I used those exact words somewhere in the DIY post!: http://www.skylinesaustralia.com/forums/topic/301992-diy-fix-cluncking-noise-in-dash-r33s/
"For the life of me" I couldn't get my hand in there either. I scratched up the back of my hand quite a bit and could just manage to get a fingertip on the side of one of the bolts. I pulled out the glovebox, the aircon vent on the passenger side, the stereo and facia, the vents... there is just no way of getting to it.
Luckily, I have pulled my dash out before when it needed new airbags, and I've had my cluster out a few times to fix the tacho and change globes... same with the stereo. Once those are out, it's just a couple of screws per panel and eventually the whole thing is ready to take out of the car. That's the stage I was at but the last time I pulled it out of the car it had no front windscreen in it. I don't know if you can take it all the way out with the screen still in, so I just got to that point and then lifted it up so I could two hands in there easily.
Honestly, to do it right (especially if you have bought a new actuator), you should just bite the bullet and pull the dash up. It is extremely easy. If you haven't done it before it looks daunting, but trust me... it's very very simple.
If you undo a nut and take a panel off, put the nut back on the thread afterwards. If you take three screws out and pull a panel off, pop the screws back in the holes of the panel and put masking tape across it so they don't fall out or disappear. I think I can pull a dash out in about an hour now, but the first time you just undo stuff and wiggle until you work out what's holding something in.
The bonnet popper got me the first time, but it's just two bolts and you slide it down.
The surround of the glovebox is held on with clips after the screws are removed and I broke one of mine as it came out. I glued and graphite powdered it back together and it's perfect again.
The a-pillar covers were a bit of a dick... you're supposed to remove the c-pillar (rear window) covers first, as the a-pillar covers slip underneath them. I unbolted the passenger grab-handle and slipped the a-pillar cover down and out of the back piece and then gradually popped the clips towards the front.
So, bad news is: no other way if you can't reach it.
Good news is: it's easy and I am 100% confident that anyone can do it in a weekend the first try if you have basic tools and persistence.
If you don't already have these, I highly recommend these tools for any interior work:
http://www.supercheapauto.com.au/online-store/products/SCA-Door-Trim-Remover-Set-5-Piece.aspx?pid=282096
You won't scratch any of your interior with these, and the thick pry-bar is excellent for popping clips that have never been unpopped (a-pillar in particular).
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
