Selling off lots of parts as building up a new engine and car out of my gtr32
Garrett 2860 -10's with standard dump pipes I believe they are, one is damaged at last track day, looks like it needs a new core, exhaust compressor housing but haven't pulled it apart. $900
Splitfire coil pack hardly used but had it for some time. 300
Gtr32 cold air intake polished kit with apexi pods, 300
White line sway bar. 100
Factory g sensor. 250
Power steering pump and reservoir 100
Oil catch can and breather kit, 300
Apexi turbo timer 40
Hks blow off valves, told they are sqv, need a clean though. 270
Tomei cams A2691N stamped, told they are 260 9.1 lift. 500
Standard plenum with throttle bodies. 250
Ignition coil pack 100
Driftworks solid conversion bushes- s13/r32 to s14/r33/r34, these are brand new in box direct from uk unused, paid over 200 to get em, 100
Abs unit also for sale but not sure on price yet.
Feel free to email me or private message. [email protected] same parts are negotiable but first in will sell as I have placed them else where for sale too
Edited by stevena
  • Like 1
Will drop the turbos to 800
And hks blow off valves to 200,trying to price things to sell quickly and open for offers if they seem to much.
If purchasing pick up is from Melbourne 9-5 business hours availability, or I can send items anywhere at your cost. These parts were off my old engine and set up and aren't being used with the new set up. All parts are in working order and good condition unless specified like the turbo for example, thought that might help as I'm getting many emails asking.
Cheers guys.
Edited by stevena
price drop turbos now 500
Gtr32 cold air intake polished kit with apexi pods, 200
White line sway bar 50
Factory g sensor. 180
Power steering pump and reservoir 80
Oil catch can and breather kit, 200
Apexi turbo timer 20
Hks blow off valves, told they are sqv, need a clean though. 200
Tomei cams A2691N stamped, told they are 260 9.15 lift. 500
Standard plenum with throttle bodies. 200
Both turbos damaged? How many kms on them? Street or track use? How much psi has been through them?
Only one damaged, needs to be pulled apart to know exactly what is the issue. Other turbo is working fine. Only reason for not fixing it up and putting it back on car is we have gone to a single conversion set up. Only track use, bout 20 track days in total at 21 pound max boost, last track day when it blew was 26 pound for 2 laps.
Price drop, even open to offers so pm if your interested but don't think the price is right, as i don't like things sitting around and cash can go back into the new build.
Gtr cold air intake polished inlet with apexi pods 160
Oil catch cans and breather kit. 150
Standard plenum with throttle bodies 150
Power steering pump with reservoir 50
Turbos 470, one turbo is in perfect running order, the other looks like it needs a new core, exhaust and housing compressor.
  • 3 weeks later...
  • 3 weeks later...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
