Hey guys, new at all this turbo stuff, got an rb20det gtst. Bought a turbo with 45v3 on front and 21u on exhaust housing I believe from research it's an VG30 turbo (45v3).
The ceramic wheel has snapped off and I need a whole assembly for middle. Is this a waste of time chasing parts? What cost is involved in getting another assembly? Also I can't get the f**ker out cause it free spins where the ceramic has snapped clean off :( any help would be great.
Thanks
https://www.sau.com.au/forums/topic/426639-need-help-with-turbo/
Buy another one. The one you have is only good for highflowing. See the Hypergear thread for an example of what you could do with it.
By the way, I'm not sure whether the 45v3 compressor housing means it's VG30 or not (had thought they were 45V4), but the 21U exhaust housing is RB25 (R33). The VG30s had an OP6 turbine housing. The OP6 is the desirable one, the 21U is a bit smaller - although on an RB20 it would be fine.
Thanks mate.
Missleman cheers but I already have rb20det in my 32. Thanks for all your help guys!
Penisman, I mean Missileman :) was meant to say there's a cheap stock turbo for your motor on eBay
hi guys I have a rb30 series 2 motor in my vl commodore and am wanting to turbo it just wondering what advice people can give me on what to do and where to get the parts from im doing it to a budget so any help would be great thanks :no:
Edited by Trenta44
It is a bargain. What are you? A moron? Less than a grand to take a (blown and therefore useless) stock turbo to a better than 250rwkW responsive bolt on turbo is good value.
I swear, you are not looking like good value yourself.
a brand new watercooled billet ball bearing turbo will cost u not much more and have a greater power output, but the highflow option is good if on a tight budget
This is yet another example of a time where if you knew anything (in this case about Hypergear turbos) you could have saved yourself looking like a fool by simply not posting the above tripe.
Fact: The suitable brand new reputable brand equivalent turbos cost about twice what a HG highflow costs. We're talking Garret here or possibly FP or precision, not Kando.
Fact: the HG highflow is pretty much just as good. And billet.
And yet again I have had to deliberately click to show your hidden post so I can see what sort of wrongness you are posting for the poor OP to get confused about.
he didn't say reputable brand, and if this guys budget is fixing a dead turbo why wouldn't he use a kando?
if you have no money replace it with a stocker, but seriously with turbos your better off getting a new one, or a off the shelf re-con'd HiFlow one, else you will end up shooting yourself in the foot.
  • Like 1
Fact: his ceramic wheel can't be replaced, so how do u get billet from that is rather odd!
Fact: to say a vg30 highflow will be "just as good" as a GTX or or HTA is beyond me, theres no way the highflow HG will match the flow output of the GTX, it will make heaps in the top end)
As I sad b4, go the highflow if your on a tightbudget, but if you're thinking long term power, then better of holding off and putting your money into something thats gona get the job done with ease, as well as having more reliable core etc
Thanx, non night
truth is kandos turbos have questionable service
truth is you can still buys ceramic turbos http://www.nissanparts.cc/catalog/?section=1060
truth is hyperger remanufacture stock turbos with billet compressor wheels with excellent service and a low price
truth is once someone is on your ignore list never ever respond to their trolls
motor out, RB25DET stocker in, cheapest way to do it :)
  • Like 1
Why would you want to replace the ceramic wheel? Its the weak point
HG (as far as I know) will replace the turbine wheel and shaft assembly with a steel item and bore the housing out etc. There is quite a bit he can do with the stock turbo, im just not sure the limits of the 21U and OP6 off the top of my head. Its a good option on a tighter budget. Even an all new HG turbo is just over $1000 depending on what you want. And believe me when I say this, because im coming from a much bigger brand turbo then Kando, the service that Stao (HG) provides is worth ever dollar you pay. Having local and helpful support is a great thing to have
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
