Gday Fellas,
Im relatively new to the forums. I have always been a lurker. Sitting in the shadows watching other people build things and then hopefully implementing them on my own car.
It all started in early 2012 where i finally decided to bite the bullet and visit Mastercars Blacktown to purchase my very own r34 gtt. I fell in love with the red r34 they had sitting there for the last month and I knew i had to have it.
After a little bit of haggling here and there I ended up buying this:
It was a clean example with a factory sunroof.
The only aftermarket parts were:
18" rozza wheels
blitz turbo timer
hks hiper max d coilovers
Im not really looking to build a track car. Just something clean and streetable that packs a punch. let the modding begin
https://www.sau.com.au/forums/topic/426655-the-red-lady-sandybangs-r34-gtt/
Everything was looking great at this point.
Here is my engine bay:
I got all the fluids (clutch, diff, oil, coolant etc) all drained and replaced.
I soon realised that i needed to get my brakes done.
So i went from this:
To this:
And i always wanted a bit of woosh so i ordered this from nengun:
and just to keep it somewhat legalish i got this from hi octane motorsport:
Now in order to prepare my car for better flow I was on the hunt for a decent exhaust system. I ended up with a nismo turbo back exhaust (including genuine nismo hi flow cat) that i got for a bargain!!! Such a sweet note on the car when you open it up and none of that annoying drone. And it looks kind of stockish.. not really.
And to further improve my flow I purchased and installed a black series kkr intercooler from otomoto. Does not have the same flow as say a blitz or a hpi but i am quite impressed for $400 brand new with piping. And it didnt require much cutting at all
Finished product:
Also changed the parkers to smd leds:
Edited by Therealsandybang
I ended up buying 19" starcorps for some fat fitment. They started off being like this:
To this:
On the car they looked like this:
But i was never really happy with them. It was way too bumpy and the wheels felt heavy. I ended up going back to my trusty rozzas
I also decided to remove my old clutch and get a new custom exedy single plate organic clutch kit from western clutches:
old:
new:
It was a bit heavy for the first 700km but now is quite nice.
Got some new gauges. Not sure if too ricey?
First I went and bought some supplies :
The rb26 bov has a larger pipe so instead of using an adapter I used the original factory pipe inside the new radiator pipe as a collar. I sealed the space between them with gasket sealer.
I was originally going to use a rubber gasket glue to attach the rb26 bov. It appears that the gasket from factory is a much better option if it is in good condition.
There was a bit of dirt And grime on it so I sanded it lightly before:
After:
Here is a comparison. Left is the neo and right is the gtr
Before:
After:
I also replaced the heat shielding stuff.
And after all this I still get the fart noise.
Lol oh well
I've just gotten my drainage sill things painted under the hood and in the boot. You can tell in my previous pod box image that the sills were faded and slightly rusting.
Same story in the boot.
I've got a nice clip on rear camera kit from carbon car systems. It's a factory looking fit.
I also hardwired a dash cam and hid the wires.
This is a pic of my universal washer bottle and pump fitment. I got it in the factory position. Yeah!!
Repainted the rozzas a grey carbon with gold flecks
And some door protectors. I know it's granny spec but it protects my doors lol
There was a cleaner factory option in s2 33s which icouldnt find for a 34
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
