hey mate, just want to say yours is the only red skyline Ive actually liked...so well done.. i normally don't like red on cars period :)
im running a simmilar settup to what your looking at... 720cc injectors/z32/nistune/atr43ss2 and im making 265rwkw at 18 psi but have a top end restriction so once i sort that out il be seeing closer to 300
its a great turbo man... lose a little bit of response but it kicks you in the face when it hits... as for the intake pipe i would seriously consider getting that replaced with a metal one at anything over 220kw (from past experience)
cheers man. keep working hard..
gtt master race mate! +1 sub
  • Like 1
Timmy just asked him about it!!!! He said it should be sweet. Very excited. The old wallet is taking a beating.
My next problem:
Should I install my turbo and replace exhaust gaskets and drive up to central coast from western sydney?
or should I pay to have it fit in there..
There is a big price difference. Some people say its fine. Jez is advising against it.. I am unsure what to do
Yeah I wouldnt drive it untuned... or if you have too I wouldn't hit more then 3k rpm as well as not driving very far
Have a look around for cheap tow.. or maybe even see if someone on here has a car trailer you can flick some dosh their way.
Good luck either way mate itl be fun when its in!
  • Like 1
i put a hypergear highflow on mine many years ago and drove it to the tuner.. going to central coast though you're bound to put it on some load going uphill which might be a risk
tow would be silly expensive.. If it was me 2 yrs ago I would of risked it if it was a relatively standard setup and done something like leave the actuator off so it was a pig with no power, would use a full tank driving that far easily though
  • Like 1
Maybe I'm alone in having driven with my highflow fitted for around 6 months running on a 10psi actuator - the ECU seemed to handle it fine (I did disconnect the factory boost control).
If you had a bigger actuator / higher boost, that would definitely be a problem though.
  • Like 1
Joey!!!
I wish I could as they are right behind my house. But they seem pretty busy for the time being as I haven't heard back from my enquiries yet. I decided when I go the e85 route and get an ecu I'll do it with them for the final form
Hopefully jez will help me with my daily duties for now.
Man you gotta go in and see them, they deal with bulk time wasters so at times they may be too busy to reply or call back. If you see them face to face the they know your serious. Even after all this time I always going in and have a chat to the boys if I need stuff done :)
They should still be there when you finish work and if you can't get Yavuz make sure you get a hold of Mark
  • Like 1
Yeah that's probably why I think. That's fair enough. I've only heard good things. I have been there before a while back briefly. I don't know them personally though. I've already committed to jez. So we will see how it goes.
Put a leather steering wheel cover. Turned out okay
My leather was all cracked and spliting on my standard wheel so I put a JDM S15 wheel in wiring harnes is the same as r34 so the airbag & horn plugs straight in :)
Edited by DoseVader
