Uh oh ran into trouble... Turbo is struggling to make power. So far the airbox has been eliminated as cause. May be Nismo exhaust or turbo. Only making 230kw at 18psi tapering to 15. Cam timing is correct.
Jez is on it trying to diagnose.
Boost leak could be the issue but then again, its Jez and Im sure he would have picked it up at 1st sight.
If you want to test the cross over style FMIC setup. I have a spare Hybrid intercooler core & Im sure someone would have a spare set of pipes for the cold side for you to test?
Hope it's a simple fix mate. I know Stao did a but of comparative testing for intercoolers and found the blitz and similar turn flows had a much higher pressure drop compared to the other style. Definitely wouldn't account for that much of a loss though, mines certainly fine.
I hope it's not a compression issue. Fingers crossed for you
  • Like 1
Thanks raj!!! I have my old cooler just a Kkr front mount and pipes That should be good right ?
Should be a good start in trouble shooting.
Cue the beer and long weekends in the garage.
  • Like 2
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
