have been watching this thread for a while just lurking so thought that I should say love the car, always been a fan of the er34 but alas my apprentice mechanic wages prevent this (for now). Anyway hope the tune goes well and you get to your power goal, thanks for the reading material
  • Like 1
Cheers man. I appreciate it. I used to spend hours on car sales researching and dreaming and then finally it happened with a bit of help. I hope one day you get yours !
I dont have the new version of the ss2 but if you do one day get a bit bored of it and do want quicker response and a bit more power, im sure stao could easily "up grade it" to the new trim.. for street i dont think itl nessasery
as far as im aware its standard in new ss2(mine doesnt spin for that long :unsure: ) but i could be wrong it maybe just the extra option.. i bought mine as a old stock clearance for a steal about 8 months ago
PS - this could be the "new version" im thinking of http://www.hypergearturbos.com/index.php?route=product/product&path=72&product_id=67
-- man... id love to do an r34 brembo upgrade like the guy on that blog haha to dream! thats a hell of a r34gtt
sickdoeoccm ffndkdlcmwlqpqlwlsksmms!!! Rushed my car to my mechanic late at night. The hose to the heater matrix in the engine bay melted or ripped off. Wtf. Coolant pissing everywhere and falling on the exhaust. It was embarrassing my car was steaming all the way there.
No over heating occurred but it was still embarrassing. Minor issue. Easy fix but wrong timing. And then during the fuss this happened
Alright. The car has been dropped to dvs jez
Got some intake ,turbo ,exhaust gaskets. And studs plus copper stoppers all genuine Nissan
Ordered this from jez to Pop in
Liked this at his workshop.
New items for more flow from just jap are being fitted on as we speak pre tune.
Pretty concerned about sound and legality of cat. I'm still keeping the Nismo muffler. Not a fan of drone or mega loud exhaust off boost at low rpm. Anyone have any experience or advice?
So far I've been told to pop a resonator in between if I hate the noise. Which sounds like a good idea.
Edited by Therealsandybang
Advice on exhaust? Straight through all the way!! :P
  • Like 2
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
