Sorry if this is in the wrong thread by the way
To start off Ill speed this up long story short needed a new daily. Over bombs decided to look for one came across a clean r33 for a decent price and took it for a drive and really like it low kms log books
And you can probably guess I bought it
The only one thing I faulted it on while I test drove it was a small noise (ticking noise) on boost for a little but nothing to serious. But being on a test drive I didn't want to flog it too hard and break something blah blah. Plus I was on a public road etc
Noticed it was a bit laggy but nothing to bad. Besides this is my daily now. So I can spend more on my 32
So yeah bought the car. Still does get up and go but yeah here's my issue/s
Before I get into aswell I will mention its close to a dead stocker. Pretty sure it has a catback and I did notice a boost tee down the back end of the dash up near the pedals I was told the old owner was an old fella and everything seems on par. It's well looked after. Original mats in good condition
Now bar those 2 things. It's completely stock.
It's also auto please remember this to help determine the problem
Now. When I picked it up again I heard that noise the ticking on boost
But went away very quickly. Hadnt heard it again today
Then today dead cold start it was doing it while on any boost at all (I don't go and boost my cars cold) but in this case I want to sus it out
It went away reasonably quickly when the car warmed up more or less and hasn't done it all night once again
But we did drive up to spring wood. Tonight up near the blue mountains. And it's a cold night if your not familiar with sydney. And it's damn cold up there
I did give the car a fair bit up there then when I let the look out it made the same ticking for a while and was reasonably warm
But eventually went away
It does sound like a gasket leak but I've never heard or experience one that went away? Sounds more like its coming from the passengers side and you can hear it in cabin with the windows up
That's problem one
Problem 2. It has a little boost guage. When I really boot into it, it will drop back - few gears start revving hard. The boost guage shows 9 psi and the car sounds like shit
So being worried of engine noise I locked it in 2nd and gradually built up revs with no boost if you get me and the motor sounds healthy revs great etc
So I tried easing into boost in 2nd. And it runs great around the 6-7 psi mark and being busy with driving couldn't see if I got it to 9 that time but yeah surged a bit with the boost like pull then it would cut out then pull again
But driving it this way the car makes heaps more power and doesn't sound so uhhh dying pulsar like its very hard to explain. Not to mention as well when it drops back really hard it just revs no boost. For a while it says I'm cranking 9 pound once again but not moving
So yeah not sure what I'm looking for
I'm sure ill figure these problems out on my own in good time but figured IDE see if you guys could cut my time
Not to worried if the turbos on its way out I can just give it a hand me down off my 32
But any help will be greatly appreciated. Thanks guys
If it's detonating that's the worse thing for your car ever. Other then that take it to a reputable mechanic to suss the problems - as it sounds more then just a boost leak
Never buy a car without a mechanical inspection no matter what
Edited by discoPumpkin
Also got a ticking noise in my rb20det.. I thought it was the tappets until I stuck my head in there.
Sounds like it's either an exhaust leak or something under my cam cover..
When you slightly accelerate it gets faster and sounds (to me) that as you get faster its like swinging a rope around really fast and you get that whistle of air as it swings around...
I really didn't explain that very well :/
Unlikely to be detonation. I know "ticking noise" screams detonation to everyone....but it's only on 9 psi. Unless the ignition base timing has been wound up a lot, it shouldn't detonate.
I would also suggest a leaky turbo or manifold gasket. It's probably lost at least one exhaust manifold stud. Get a torch and go have a look for missing nuts/studs.
The shitfull running is probably because R33s stand a good chance of going into R&R by the time the boost is up to 9 psi. Bypass the boost T and see what the boost comes back down to, and if it runs better.
Also on reference to the car sounding like shit. Try imagine a swift gti or something little at very high rpm where power drops off
Like that or maybe it doesn't sound like me 32 screaming off its head with the sweet sound of rb
I don't hear any pinging. And I think I've heard detonation before so I'm pretty sure it's not that either.
It sound very very similar to a exhaust gasket leak but it goes away when it's warm/hot basically I will get some time this week to have a good look into it check studs etc
Lower the boost.
Fresh oil.
You're likely to find it's a lazy lifter not pumping up making it tick.
Power cutting in/out is likely something like R&R or exceeding the AFM voltage etc, or the coil packs are dieing and it's miss firing.
Doesn't sound like detonation at all.
And you don't need a mechanical inspection if you know what you're looking at.
Lower the boost.
Fresh oil.
joking or? He's running 9PSI and to lower it to 5 what would that achieve apart from masking the issue and loosing power
I'm not a mechanic and I think I know what i'm looking at, however if I brought a car without a second opinion or full mechanical inspection, then I bloody well deserve the thing to blow up on me next week!
But it's lucky your a mechanic as u can inspect the vehicle yourself..
9 pound on a stock ecu series 1 r33 can cause it to go R&R stock is 7 above about 4000 rpm. With a small boost leak it can cause it to R&R and going by what he is saying. Sounds bad and goes nowhere it seems like this is the case. Aslo he will make more power with the lower boost as the ecu will actually run some decent timing as aposed to more boost where it will just pull it all and feel like a piece of play dough.
U did wot mate? get more power by running less boost then 9psi, now I've heard it all, leaving the thread
ps fix the boost leak instead of lowering the boost to compensate 4 the leak ffs
Oh my god will u just turbo youre NA GTS already, afterall this is the forced performance subsection where people with turbos should only be giving valued advice and opinions, rather than a kid on his learners trolling
Theres an NA thread tho, u would be really helpful in that section, take care
You say the ticking noise went away once the car warmed up, I think that would suggest noisey lifters, detonation would get worse with temperature and with hard driving. The auto would have higher gear ratio's and possibly bring on the R&R earlier than a manual? GTSboy might confirm this?
no disrespect here, but GTSboy knows what he's on about !! If you don't know what your talking about you need to pull your head in and not look like a goose
:yes:
Edited by AngryRBGTX
Auto ratios are same same in R33 (4.08 vs 4.11) so it's not that. The noisy lifter idea is the other likely one.
Stupid pumpkin doesn't even know that other manufacturers made cars with the GTS appellation. Some of them were very large V8s. Like my Monaro. My 1971 Monaro. That I owned in the 80s.
Little boy should shut up, shouldn't he?
You obviously have no idea about how an engine works. You cram more boost into an engine but if your timing retarded as R&R makes it, you will make no power.
Come back here when you actually have some input into this thread.
Also back to the point you made about it being a bit laggy. I had a problem once where the stock waste gate actuator was not preloaded enough making it open slightly when not on boost. Made a ticking noise similar to what you were describing. Had me stumped for ages, changed all the gaskets around the turbo and still the ticking noise. Finally checked the actuator, noticed it wasn't preloaded properly, took it off, bent it a little and bam fixed my lag and that mysterious ticking noise :blink: .
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
