Sorry if this is in the wrong thread by the way
To start off Ill speed this up long story short needed a new daily. Over bombs decided to look for one came across a clean r33 for a decent price and took it for a drive and really like it low kms log books
And you can probably guess I bought it
The only one thing I faulted it on while I test drove it was a small noise (ticking noise) on boost for a little but nothing to serious. But being on a test drive I didn't want to flog it too hard and break something blah blah. Plus I was on a public road etc
Noticed it was a bit laggy but nothing to bad. Besides this is my daily now. So I can spend more on my 32
So yeah bought the car. Still does get up and go but yeah here's my issue/s
Before I get into aswell I will mention its close to a dead stocker. Pretty sure it has a catback and I did notice a boost tee down the back end of the dash up near the pedals I was told the old owner was an old fella and everything seems on par. It's well looked after. Original mats in good condition
Now bar those 2 things. It's completely stock.
It's also auto please remember this to help determine the problem
Now. When I picked it up again I heard that noise the ticking on boost
But went away very quickly. Hadnt heard it again today
Then today dead cold start it was doing it while on any boost at all (I don't go and boost my cars cold) but in this case I want to sus it out
It went away reasonably quickly when the car warmed up more or less and hasn't done it all night once again
But we did drive up to spring wood. Tonight up near the blue mountains. And it's a cold night if your not familiar with sydney. And it's damn cold up there
I did give the car a fair bit up there then when I let the look out it made the same ticking for a while and was reasonably warm
But eventually went away
It does sound like a gasket leak but I've never heard or experience one that went away? Sounds more like its coming from the passengers side and you can hear it in cabin with the windows up
That's problem one
Problem 2. It has a little boost guage. When I really boot into it, it will drop back - few gears start revving hard. The boost guage shows 9 psi and the car sounds like shit
So being worried of engine noise I locked it in 2nd and gradually built up revs with no boost if you get me and the motor sounds healthy revs great etc
So I tried easing into boost in 2nd. And it runs great around the 6-7 psi mark and being busy with driving couldn't see if I got it to 9 that time but yeah surged a bit with the boost like pull then it would cut out then pull again
But driving it this way the car makes heaps more power and doesn't sound so uhhh dying pulsar like its very hard to explain. Not to mention as well when it drops back really hard it just revs no boost. For a while it says I'm cranking 9 pound once again but not moving
So yeah not sure what I'm looking for
I'm sure ill figure these problems out on my own in good time but figured IDE see if you guys could cut my time
Not to worried if the turbos on its way out I can just give it a hand me down off my 32
But any help will be greatly appreciated. Thanks guys
If it's detonating that's the worse thing for your car ever. Other then that take it to a reputable mechanic to suss the problems - as it sounds more then just a boost leak
Never buy a car without a mechanical inspection no matter what
Edited by discoPumpkin
Also got a ticking noise in my rb20det.. I thought it was the tappets until I stuck my head in there.
Sounds like it's either an exhaust leak or something under my cam cover..
When you slightly accelerate it gets faster and sounds (to me) that as you get faster its like swinging a rope around really fast and you get that whistle of air as it swings around...
I really didn't explain that very well :/
Unlikely to be detonation. I know "ticking noise" screams detonation to everyone....but it's only on 9 psi. Unless the ignition base timing has been wound up a lot, it shouldn't detonate.
I would also suggest a leaky turbo or manifold gasket. It's probably lost at least one exhaust manifold stud. Get a torch and go have a look for missing nuts/studs.
The shitfull running is probably because R33s stand a good chance of going into R&R by the time the boost is up to 9 psi. Bypass the boost T and see what the boost comes back down to, and if it runs better.
Also on reference to the car sounding like shit. Try imagine a swift gti or something little at very high rpm where power drops off
Like that or maybe it doesn't sound like me 32 screaming off its head with the sweet sound of rb
I don't hear any pinging. And I think I've heard detonation before so I'm pretty sure it's not that either.
It sound very very similar to a exhaust gasket leak but it goes away when it's warm/hot basically I will get some time this week to have a good look into it check studs etc
Lower the boost.
Fresh oil.
You're likely to find it's a lazy lifter not pumping up making it tick.
Power cutting in/out is likely something like R&R or exceeding the AFM voltage etc, or the coil packs are dieing and it's miss firing.
Doesn't sound like detonation at all.
And you don't need a mechanical inspection if you know what you're looking at.
Lower the boost.
Fresh oil.
joking or? He's running 9PSI and to lower it to 5 what would that achieve apart from masking the issue and loosing power
I'm not a mechanic and I think I know what i'm looking at, however if I brought a car without a second opinion or full mechanical inspection, then I bloody well deserve the thing to blow up on me next week!
But it's lucky your a mechanic as u can inspect the vehicle yourself..
9 pound on a stock ecu series 1 r33 can cause it to go R&R stock is 7 above about 4000 rpm. With a small boost leak it can cause it to R&R and going by what he is saying. Sounds bad and goes nowhere it seems like this is the case. Aslo he will make more power with the lower boost as the ecu will actually run some decent timing as aposed to more boost where it will just pull it all and feel like a piece of play dough.
U did wot mate? get more power by running less boost then 9psi, now I've heard it all, leaving the thread
ps fix the boost leak instead of lowering the boost to compensate 4 the leak ffs
Oh my god will u just turbo youre NA GTS already, afterall this is the forced performance subsection where people with turbos should only be giving valued advice and opinions, rather than a kid on his learners trolling
Theres an NA thread tho, u would be really helpful in that section, take care
You say the ticking noise went away once the car warmed up, I think that would suggest noisey lifters, detonation would get worse with temperature and with hard driving. The auto would have higher gear ratio's and possibly bring on the R&R earlier than a manual? GTSboy might confirm this?
no disrespect here, but GTSboy knows what he's on about !! If you don't know what your talking about you need to pull your head in and not look like a goose
:yes:
Edited by AngryRBGTX
Auto ratios are same same in R33 (4.08 vs 4.11) so it's not that. The noisy lifter idea is the other likely one.
Stupid pumpkin doesn't even know that other manufacturers made cars with the GTS appellation. Some of them were very large V8s. Like my Monaro. My 1971 Monaro. That I owned in the 80s.
Little boy should shut up, shouldn't he?
You obviously have no idea about how an engine works. You cram more boost into an engine but if your timing retarded as R&R makes it, you will make no power.
Come back here when you actually have some input into this thread.
Also back to the point you made about it being a bit laggy. I had a problem once where the stock waste gate actuator was not preloaded enough making it open slightly when not on boost. Made a ticking noise similar to what you were describing. Had me stumped for ages, changed all the gaskets around the turbo and still the ticking noise. Finally checked the actuator, noticed it wasn't preloaded properly, took it off, bent it a little and bam fixed my lag and that mysterious ticking noise :blink: .
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
