Got a bit more done, pulled the motor and gearbox out of the rusty yellow shell to start fitting the sub frame adaptor plates into the hatch.
Pauls, I want to get full rego to show what can be done under NCOP, the club rego is the last resort but even with the vic club rego the inspection is
still done by a VASS engineer. It's surprising how many skyline owners have a soft spot for toranas and on the gmh-torana site a lot of torana owners
have a soft spot for skylines. I suppose physically they are both about the same sized car and both are Bathursh winners.
A lot of people were heralding NCOP as the end of the modification world. I truly hope to see this project of yours go through with engineering approval to get full rego to show that if the quality of work and engineering practice is good, you can still have your toys. Your attention to detail and quality of work has my respect.
  • Like 1
Nice work! i've been lucky enough to have a father who was a spray painter,over the years i have watched him do up 13 toranas of his own and im just as excited to see yours finished as i was his.Keep up the good work mate. :thumbsup:
Edited by gleeson
Got some more done, tacked in the rails and fitted crush tubes for the subfame adapter plates.
Made 4 bosses to fit into the original torana subframe mounting holes. These are welded into the top and bottom of the rail to help tie it together and allow for another mounting point.
Started fitting the suspension towers.
  • 3 weeks later...
Cut the tunnel out of the skyline, it made me a little sale to destroy such a nice car.
Also talked to the engineer about track width and tyre and rims sizes, found out rim size is now determined by taking the
widest tyre offered and increasing it but 30% then use the tyre fitment guide and see what rims suit that tyre.
Since i'm using the skyline suspension and sub frame I can use the skyline track width and tyre/wheel combination.
So R32 gtr had a 225/50r16 I can run up to a 285 on the front and the R33 had a 245/45r17 which works out to being up to a 315.
But I can only change the track width by 25mm.
Sat the skyline tunnel in the hatch.
Extreme ATTESA pump removal.
Ive been on sau for about 10yrs and ive never seen anything as unique or exciting as this build...thanks for sharing - u are using the 2 most appealing cars in my mind to create a work of art :)
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
