Started fitting the tunnel, brought some cleko's last summit order so I thought I would give them a go.
They made it a lot easier to trial fit the tunnel since I had it in and out about twenty times. After I had the tunnel neatly lapping
over the floor I started cutting 50mm at a time then tacking and hammer and dolly.
  • Like 1
There may be a career in this transformation gig once your done. Let me be the first to get in line to order same conversion please :-)
I have owned multiple LH/LX Torana's and also multiple R33 Skylines - they are both(by a country mile) my favourite vehicles.
So if you feel you you would like do repeat the process once this one is complete - I'm here........admiring your talent and frankly great taste in cars :-)
Dean, I've had a couple of people contact me about doing the conversion for them but i'm to busy doing my own projects.
Bit more chopping.
Before fitting the rear section I made a 100mm dimple and then cut a 90mm hole in the centre.
Setting in place.
This is the reason for the hole.
All the tunnel is now welded in, also re-shaped the cross brace under the back seat that I cut out to fit over the new tunnel,
this will be welded in after the engineer does his next inspection. Also started the drivers side seat mounts.
Thought that was a joke haha, couldn't get a helper i guess.
God knows why! If I lived within 100km of this build I'd jump at the chance to be a helper. Although I doubt whether I'd be worthy enough to be in the same shed as this masterpiece.
Had the engineer look at it today, he was happy with what I have done so I finished welding in the seat mounts and the cross
brace under the back seat. Also sat the steering column, seat and centre console in to see how they looked.
Edited by turbo76lx
