Looks awesome Glenn, glad to see you're getting stuck into it again!
I'll have to drop around for a look soon.
The Torana hatch is definitely a shape that can be made look very nice. Big arse flares are certainly a good start to that!
Started extending one of the front flares, thought I would try the tape and bog trick.
Cut the bottom off the flare and screwed both parts to the guard.
Put masking tape across the two.
Mixed up some bog and towelled over the tape and also cut some tig filler rod that I pushed into the bog to give it some extra support.
After the bog was dry I remover the flare and fibreglassed the inside.
Still needs a lot of work but should come up ok.
Got the other side flares done and put it on the ground to see how it looks.
This is with no springs sitting on the bump stops to check clearances.
This is at standard ride height, will probably lower it about 20mm.
  • Like 4
Decided to try and for Currie Enterprises Johnny Joints to the front caster rods since the rubbers are flogged out.
I think these will be ok considering they are used in the suspension of 3 ton rock crawlers and the engineer is happy with them because of the urethane bush.
It's a pity it wasn't 0.4mm bigger in diameter then it could have been pressed in and not have to weld it.
Tapped a new thread for the grease nipple through the castor rod and lined it up with the grease nipple hole in the johnny joint then welded it on both sides.
Also dropped the motor, turbo and dump pipe back in to see if the brake line will clear and be far enough away from the exhaust.
  • Like 4
Started filling in the gap from cutting the body to clear the tyres, because I've had to cut so high I had to weld the two inner panels together first.
The fun of welding through tar, body deadener and paint.
Little bit of rust in the lower 1/4 so easier to just cut the whole section out as this is covered by the flare.
One side done.
I always liked the drop tank style look on the old SLR5000 Toranas.
If you wanted to keep that style, maybe you could speak to Julian at Aftermarket Industries about a fuel cell setup that replicates that and incorporates baffling and a surge tank internally.
He does amazing work and comes highly recommended for all sorts of fueling work.
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
