To tight to buy a new thermostat housing, so simple, I just made one.
Also started to extend the top timing belt cover, it had a crack and a piece missing so it was easier to cut the small section out and replace it at the same time.
  • Like 4
  • 2 months later...
Bit of an update, had a small side project for my boss in Melbourne which turned into a bigger project fixing a previous dodgy repair.
The front section of the rail had been repaired before and been fully sealed up not letting any water that happened to get into the rail escape out the bottom.
So the rail rusted from the inside out.
When i cut the outside of the rail out i found it had a welded inside of the rail on the inner.
After removing the inner plate i was left with this.
From this point I cut the inner out and fabricated a new rail and repaired a few more rust patches.
Sorry no photos of the finished repairs I was to keen to get this thing out of my shed.
Now back to the hatch, not a great deal has has happened except planning and procrastinating but I have started seam welding some of the body.
  • Like 3
  • 3 weeks later...
Got a few more things done.
Checked it see if the power steering lines could be reused, will need to modify the hose on the power steering pump.
Replaced the front wheel bearings.
And started getting some of the suspension parts striped for painting.
  • Like 2
  • 3 weeks later...
Well today I thought I would touch base with the engineer to see at what stage he wanted to see the car next only to be told by the receptionist that
he has recently lost his VASS accreditation. Looks like the $1000 I have spent with him is a total loss and I don't even know if he has any documentation
he can give me to pass onto a new engineer when I find one. So now the search for a new engineer start and hopefully find one that is happy with the
build so far.   :banghead:
Edited by turbo76lx
Shit mate, that's no good. If your current (now ex!) engineer doesn't recommend someone for you PM me and I'll track down the details of another engineer who comes to Shepp fairly regularly. We sold him a Benz not long ago and I spoke to him about engineering my car with the RB30 in it. He was pretty confident he'd get it through whereas others just instantly shit canned the idea so he's at least open to a little lateral interpretation of the VSI regs!
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
