  • 1 month later...
  • 2 months later...
Bit of an update, got the front flares to a point I am happy with.
Started on the rear flares, cut the bottoms back off and started again.
Wasn't happy with the bonnet hinges I made so decided to use VE commodore boot hinges, had to create a pocket each side for the hinges to sit in.
Also welded up some holes and seams in the engine bay.
  • Like 7
  • 4 months later...
The motor has been dropped off at JPC and the seats are at the trimmers.
Cut off the sill to repair the damage.
A9X_0326_resize.thumb.JPG.fdcd881b7d495a75dfc15ae80758a638.JPGA9X_0331_resize.thumb.JPG.145c3361d04b751fe060db51d9f18382.JPGA9X_0337_resize.thumb.JPG.446a6f9ffd9ac0229637073ea219cbe1.JPG
Had the shell dipped at Recoat paint stripping and have now started spraying the epoxy/prime.
A9X_0367_resize.thumb.JPG.a535e0a84ba02957099127e10660315f.JPGA9X_0394_resize.thumb.JPG.768f75669ffb32abb382935ed32bb676.JPGA9X_0396_resize.thumb.JPG.a8b104121d4f9f16cb24f756fec06e07.JPG
  • Like 7
Yes had it dipped at Recoat paint stripping, they work out of their shed behind their house. I don't think Recoat smash repair are going anymore after the death of a worker the other year.
  • 2 months later...
Update time. Having the shell dipped has turned out to be more work than I thought.
About 14 holes have been drilled in the shell that they never told me they were going to do so these had to be welded up.
Yes that is a hole drilled in the middle of the roof skin.
I was surprised at the amount of rust that started to form under panels, I had tack welded the sill panel and two extra roof braces on to the shell and removed them when I got the shell home.
There are also spots where it looks like acid is still leaching out of the seams.
A9X_0399_resize.thumb.JPG.d734ffef3962fade3451ea325c3a0d36.JPGA9X_0400_resize.thumb.JPG.a6e553ccf8c207c9fa18260d84015fc2.JPG
I was also surprised at the amount of body deaden-er and seam sealer that was still in the shell.
The black shape in the middle of the photo is one of the many big of body deaden-er.
I have had to strip and clean and sand every part of the shell so finally got the inside and underneath painted with KBS.
One coat of silver KBS, still need to seam seal then a coat of black KBS.
  • Like 4
Were the holes for drainage? breathing?
And yes, poor form not to at least advise. Maybe they assumed you knew? First I've heard of it but I have never done this level of work to a shell.
I've never thought of painting the inside of the body with KBS. My plan always only included doing the under body...but now you have me thinking....
Will this be the only form of sound deadening in the interior, or will you still be putting something like Dynamat under the carpet? Or, is this KBS just a sealer / rust killer paint rather than a sound deadening coating?
Edited by Tenny
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
