Haha and im just a sales man.
Engineer sounds lenient. Im doing a rwd rb26 swap in my sedan and will need it engineered
Iv actually emailed this same engineer before I saw any of this a few days ago now for my r31 with an rb25 in it. He's in braeside somewhere I believe. Will see what he says soon hopefully, I'm in the same boat as you.
Started on the radiator it's a HQ ebay radiator with a fan shroud I made to suit twin 12" spal fans and I moved the bottom outlet.
There's about 6mm between the power steering pulley and the fan.
Also mounted the 45mm turbosmart hyper-gate and tacked up the dump pipe. I'll finish the dump pipe when I get the flex
coupling that will be cut in the 2" tube after the wastegate.
Welded up the intercooler and piping and also fitted the synapse diverter valve which will be plumbed back to the air box.
Also started the chassis strengthening using 89x89x3.5 rhs shaped to suit the floor pan.
That poor Torana! Will be interesting to see what it weighs with all the Nissan gear in it - I'm betting it will be less than the R32. Can't wait to see the final product - great project turbo76lx!
wow, your fabrication skills are sensational!
No doubt you know your stuff!
Given your torana is 25+ years old, why not go club plates which will give you 90 days road use a year?
You obviosuly know what your doing and are bouncing your approach off engineer before application, club reg would allow you to bypass expensive engineering approvals and get you legal road use for under $200 a year.
I love old Torana's and Skylines so what's not to like here. So this will definitely be interesting once complete, to see how it handles. It ought to be a farking hoot to drive whether it handles like a Skyline or not, but I wouldn't be surprised if you find it holds the road in corners pretty good, with a nice drift every now and then when you want it. I wish I had your skills to bring back cars from the dead. I see plenty here in tas that need love and attention, but they just sit there rusting away.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
