Was a fairly good weekend.
Could actually say I had an off day at the track, things didnt feel right.
cross entered in TT and MX5 so got my monies worth.
qualified 20th out of 27 for TT and race 1 came 13th - jumped up a few spots!
qualified 3rd in MX5 outright which was awesome!
got to the start of MX5 race 1 and I had clutch engaged, in 1st and car started creeping forward. weird.
by end of race was all good and came 4th.
Race 2 TT clutch felt worse. lights went off and I took off good, could not engage 2nd and lost a bucket load of spots. got a couple back later and that race stayed 3rd and 4th throughout. last 2 laps I tried grabbibg 2nd and worked.
decided to call it quits.
then Andy's Dad Russ called me as i was bout to get some lunch. he thinks its the slave cylinder.
he had a spare and said would take 10-15mins to change over.
I 'ummed' and 'ahhed' where all the other MX5ers started to yell at me for not doing it, my wife even called me to see how I was going and told her situation, she said get the ƒü¢k back out there. yes boss!
so, changed slave cylinder and made race 2 MX5. was having great battle with Craig and Andy and Steve. I was on Daniels arse and attempted a couple moved during first 2 laps. then andy was biting at my heels. andy got passed a few times and straight away i took that position back!
then he got passed and I battled with Craig where we were both side by side at the kink onto back straight, wasnt looking good and I ended up into the dirt.
left lock, right lock, left lock at 100kms. Steve was behind me and saw it all happen, I slid back onto track, a 360 into the other infield.
mud everywhere.
TT was up next, had a etter srartm got some positions and ended up battl;ing Craig again. my arch nemisis. ended up 3rd in class A TT in trophy race.
MX5 trophy race, had a great start, after turn 2 I had Daniel on the left, Andy in front, Craig on the right. all three neck and neck, I take inside behind daniel and Andy and I neck and neck through the top, next minute BANG, I took a hit from Bill in the rear right quarter and flew off the track at turn 5. DNF.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
