  • Replies 44
R34 GT-V MODEL
2.5lt NEO 6 Engine & loom & ecu -1200
Limited slip differential(factory option) - 350
Rear window wiper assembly - 50
Driver airbag - 150
Dash pad incl Front passenger airbag - 200
ABS PUMP - 70
Power window reg - 80 each
Rear spoiler - 100
Bootlid with spoiler holes - 100
Turbo brakes (factory option) - 250
5 stud conversion - 400
Two tone front & back seats (black/grey) - 200
Climate control unit - 150
Cluster -100
Coilovers (nismo springs) - 300
Coupe front doors - 200 each
Front windshield -100
Rear windshield - 100
Alloy radiator - 100
Abs sensors (all) - 100
Steering wheel - 120
5 speed manual conversion - 1000
Interior carpet - 100
Centre console - 80
Roof lining - 50
Rear taillights - 100 each
Rear bumper including reverse lights g
** Running gear sold **
Still have all interior bits
rear lights
spoiler
nismo coilovers
back bumper
gtt brakes
abs sensors front/rears
alloy radiator
both coupe doors
climate unit
dashpad
glovebox
cluster
gearbox loom
Pedal box
******open to offers guys ******
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
