A quick video from my iphone (Taken by Carmen) of us setting up the cones, i had to laugh when Dave couldnt get the course right, we had no hope if he couldnt :P
Fkn POS iphone ran out of memory on the only full run too :rant: :dry:
To the guys that dont know who the helpers were, the fluro jackets are a giveaway :P But below you can see Eric (Pezhead) and the top of Terrys head lol (Terry_R34) who were a massive part of the day...
Feel free to say thanks to these guys online or at the next Texi, as without them.... We dont have a Texi :yes:
Ill list up a few of the others for the new guys :D
Didnt get a chance to catch up with these guys, but they were going hard all day.... Not that we could see them through the Camo :ph34r:
I was a bit of a fan of the look and sound of this thing!!! Number plates brung the lulz!!!
Guys feel free to let us know who is who so I can match a username to the cars ;)
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
