I just noticed we have missed heaps of the helpers in the pics :O lol will try harder next time to make sure everyone is in there ;)
Thanks too all the team that makes this possible as it is EPIC!!!!
got say a big thanks to all the organisers.
as a first timer i had a ball, well worth the drive, and ill be back for more.
look forward to the next one.... as i still have plenty of tyres..hehe
Glad you got back safe! Was good too meet you breifly man!
Stay in touch as we have cruises up north occasionally, and i KNOW you're not scared of a long drive haha!
i see ur havin a cruise up wotton way?
i love that drive, my first gemini and i have some great memories of that strech of road
if im free id love to tag along
Awesome! Well if you are free make sure you come along! It is only a small cruise with a few of the Newy guys but we would be more than happy to catch up or meet you along the way :yes:
Cheers for all the pic/vid love of the v35.
Surprised at how well it went when I had a bit of room to throw it around. Was useless in the tight slalom though. But cant expect much for a sstocker on street coilovers and heavy wide 19s with china tyres :P
Probably was still more suited to this kind of thing compared to my 14 being na and haveing somw form of tourqe
Day was actually quite well run and had a better atmosphere than most eastern creek days, reminded me of the old oran park days
Edited by (Locky)
It looked sweet! loved the entrance too with the speed hump scrape and then the wooden blocks :yes: Cos low!!! There are more pics of it i think :D
Thanks to the organisers for a top day
Here is two of my vids links
Haha love that second view mate! Just had to make sure you switch the view back to desktop or it doesnt work ;)
Looooove the skid video!!!! :woot: what resolution is that in?
And yes, that was gate pressure and plumb back gate so low 300kw, car has run 391kw ;)
Hoon
Wonder how the orange go kart would go at this?
Would
It even be allowed to run?
Those speed humps massacre the cross member, rails and subframe. This car hangs lower than a s/r chassis even though its not even tucking tread on 19s
Was worse going out lol
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
