probably haha
no idea then, apparently rwd stagea run s15 front suspension
More like R33 GTS-t
I can supply Whiteline caster adjustable replacement if you like; PM me.
You will need to get them pressed out/in.
It might just be that i'm tired and need to go to bed, but really ? grease leaking out of that bush ? Isn't it a pressed rubber and there would only be a smidge of grease on the part the bolt goes through ?
You sure you don't have a leak from somewhere else ?
ok sweet r34 or r33 for the adjustable radius rods? keep in mind its an rsv... afew people have told me suspension components are different, then again they could be wrong none of them own one
pm me your vin and i'll tell you the part number for the caster bushes/rods and you should be able to work out what you need from that
  • Like 1
Yep, no such thing as too much caster.
On my 180b SSS, I modified the front of the guard openings so I could get more.
lol same on both cars here
