So i made a thread some weeks ago and i had some 4wd problems and a couple of fault codes on my Attesa box.
Now i just have 1 fault code remaining and thats NR:1
Thats The Right front wheel sensor.
Been going thru the loom and it looks fine.
Started to follow it from the Attesa ECU and it should be the cables from PIN 13 and 14 that leads towards the Front Right Sensor.
A couple of CM from the connector to the ECU the cables merged into one Larger Brown protection "cable" That thing goes all the way to where the pedals is located and then the brown "cable shield" is removed and the 2 cables from PIN 13 and 14 (black and white) goes into a Connector
housing
that isnt connected somewhere.
So anyone has any idea where this is supposed to connect?
Best regards!
https://www.sau.com.au/forums/topic/426789-4wdabs-sensor-right-front/
