includes:
2x nitrous 13.6lb bottles with brackets (blue anodised) holds 10lbs of gas
1 bottle has a gauge on it
2x solenoids (fuel and nitrous) with braided lines to the bottle and to the fogger nozzle (with all the fittings already attached)
I dont have the toggle switch/micro switch, but you can pick these up for like $5 at supacheap/autobarn/repco/ebay etc
located central coast nsw.. can meet halfway depending where you are
$650ono or willing to swap for wheels & tyres
text 0468724034
post-95984-0-80641600-1370931825_thumb.jpgpost-95984-0-29001600-1370932077_thumb.jpgpost-95984-0-09828500-1370932141_thumb.jpgpost-95984-0-90208400-1370932209_thumb.jpgpost-95984-0-78964300-1370932356_thumb.jpg
lowest il take is $550 tonight/tomorrow...
wheels.. rota grids, d1rs, something of interest.. have to have tyres.. willing to put a bit of cash on top depending what they are and condition obviously.. thanks :)
p.s reason for sale... came with my car when i bought it, im a girl & have no intentions of ever using NOS lol :)
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
