Hello
So its sorta hard to explain, but ill try my best.
I have a 1998 R34 GTT Skyline, It has a rb25det NEO. It has no engine mods other then an oiled HKS Pod filter, Apexi Front mount intercooler and an Apexi AVC-R Boot contoller.
I have a problem (is most noticable in 3rd gear) where when i hit apoximatley 5000rpm power drops and from outside the car it sounds like im on red line apprently. I am still obtaining the same out of boost and injection percentage according to the Apexi AVC-R. When i set the boost at stock pressure the problem goes away. However the problem accours again when i turn the boost up. Starting at 9 psi and onward up to 11 psi! (i havent tried to go any higher) iver also tried it with traction control on and off and it makes no difference.
Please help, Do i need a tune or new plugs and coils, etc...
Thanks for your help, Im new to all this.
Alex
Edited by Shelford93
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/
jase_c I have hit boost cut before, this problem isn't as violet as that it doesn't jerk or throw me around it just looses power when I hit about 5000rpm and then it seems to get past it at about 6500rpm
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886514
I would use a compressor and regulator, but you could perhaps use a bike pump and gauge?
Just remember the pressure it takes to open the actuator is completely different to where it will crack open normally, as the manifold is filled with pressure when the engine is running.
Best to simply leave it on low boost if bumping it up is causing issues, unless you tune it...
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886811
Seems your running the stock ECU as you don't mention an aftermarket.
34GTT NEO's seem to always encounter this issue.
you could put an R32 actuator on there and stay on/around 10PSI
until you do get an aftermarket ECU or 'Nistune' and get it tuned as suggested by others.
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886820
My 34 is doing something similar around 4500rpm under load on the dyno but i think it has something to do with maxing my air flow meter out (240kw). i have some video of it i might try and upload, see if its what yours is doing
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6887883
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
