I am trying to diagnose a vibration/rumbling from the rear at speeds over 130 km/h so i jacked up the rear and pulled off both wheels, my plan was to put it into rwd and just engage first gear, stick my head under the back and have a listen, but when i engaged first gear after 3-4 seconds of drivers side hub rotating (i have my head out the door looking) a clicking noise starts (sounds rather like two gears with worn teeth that are not fully engaged and skipping) and the drivers side hub has stopped spinning and is kind of inching along. If i push in the clutch at let it out again the noise starts immediately (no 3-4 seconds of rotation) but if i run it in reverse (which seems to work normally with no noises or anything) and then go back to first i get the 3-4 seconds of normal rotation in 1st again. I'm not sure what is going on with the tailshaft and the passenger side hub while this is going on. can someone please enlighten me as to what might be happening?
thanks
(car is a 32 gtr)
To test for a wheel bearing issue, grab both ends on the vertical axis of the wheel and push with one hand while pulling with other, keep alternating and if you feel that there's some play there then it's most probably the wheel bearing. I had this issue before and had a mechanic explain it to me.
so an update......got my girlfriend to jump in the car and engage first gear while i had a good look at what was going on. Noise is coming from passenger side hub, strange thing is that the passenger side hub is rotating normally and the drivers side stops/inches along, put the wheels back on and gave it a good wiggle back and forth (top to bottom) and got abit of movement so i guess that wheel bearing is shot and causing the noise (and hopefully the cause of my vibration)
can anyone tell me why the drivers side wheel stops rotating when it seems like its the passenger one thats f*cked? is this an issue with the diff?
and when you change wheel bearings do you change the other side at the same time regardless or only if it needs it?
Well, you won't get any noise from something that ain't moving much!
The fact that both wheels are not driving the same when you are supposed to have a mechanical LSD in there (which should make them act together) means that something is very unwell in the diff. Follow advices above.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
