I am trying to diagnose a vibration/rumbling from the rear at speeds over 130 km/h so i jacked up the rear and pulled off both wheels, my plan was to put it into rwd and just engage first gear, stick my head under the back and have a listen, but when i engaged first gear after 3-4 seconds of drivers side hub rotating (i have my head out the door looking) a clicking noise starts (sounds rather like two gears with worn teeth that are not fully engaged and skipping) and the drivers side hub has stopped spinning and is kind of inching along. If i push in the clutch at let it out again the noise starts immediately (no 3-4 seconds of rotation) but if i run it in reverse (which seems to work normally with no noises or anything) and then go back to first i get the 3-4 seconds of normal rotation in 1st again. I'm not sure what is going on with the tailshaft and the passenger side hub while this is going on. can someone please enlighten me as to what might be happening?
thanks
(car is a 32 gtr)
To test for a wheel bearing issue, grab both ends on the vertical axis of the wheel and push with one hand while pulling with other, keep alternating and if you feel that there's some play there then it's most probably the wheel bearing. I had this issue before and had a mechanic explain it to me.
so an update......got my girlfriend to jump in the car and engage first gear while i had a good look at what was going on. Noise is coming from passenger side hub, strange thing is that the passenger side hub is rotating normally and the drivers side stops/inches along, put the wheels back on and gave it a good wiggle back and forth (top to bottom) and got abit of movement so i guess that wheel bearing is shot and causing the noise (and hopefully the cause of my vibration)
can anyone tell me why the drivers side wheel stops rotating when it seems like its the passenger one thats f*cked? is this an issue with the diff?
and when you change wheel bearings do you change the other side at the same time regardless or only if it needs it?
Well, you won't get any noise from something that ain't moving much!
The fact that both wheels are not driving the same when you are supposed to have a mechanical LSD in there (which should make them act together) means that something is very unwell in the diff. Follow advices above.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
