my mates done nearly the exactly the same as mine, less compression then mine, less aggressive cams and it made 180kw on 98 so that's why I was hoping for atleast 200 on e85, my engine builder is pretty positive it will make 200kw, but the proof is in the pudding!
Here is a photo of her in, heard her run for the first time today, I do have a video of it on my phone, will figure out how to get it onto here, tuning tomorrow, will try and get some video footage and decent non-phone photos sometime aswell.
Dyno sheet - Mild Tune (will push it a bit later when its proven to be all well)
Engine torque is that divided by the diff ratio. 3.7 in this case
Annnd its on a hub Dyno hence the power curve "interuptions", if it was on a roller it would be smooth as silk.
I can't read dyno sheets.. :(
Is that like 165kw?? :)
Edited by Zrobe
yeah mate 167.6 down the bottom
did end up making 170 odd by the end of the day, although I need to adjust the cam timing to get a few more revs out of her and upgrade the cat back exhaust, also tempted to get the throttle body's enlarged and sealed properly, one has a slight leak on idle causing a very minor miss, pretty sure EFI hardware will do that for me.
  • Like 1
That was just 98, E85 actually didn't make any more power but the car sounded a lot nicer, sounded smoother through the rev range aswell. which I was sort of disappointed by but in an NA build all gains are very minimal.
Not sure if this will work for most of you
https://www.facebook.com/photo.php?v=10151826649939459
Waiting for my go pro to be returned that I left at my friends place while I picked the car up so I can upload the video properly
Edited by Wayne.
  • 4 weeks later...
    • Don't take it as a guarantee. It's all a game of statistics. And on top of that, smooth over a thick layer of "quality of spanner spinning" as a further Gaussian curve of probability of failure. You play games at anything above ~400 HP, and you're using up margins in terms of engineering and luck.
    • Aye, everything is being touched and all the parts that are responsible for the oiling issues are also fixed. (Crank collar, billet prp oil pump, head return to sump, yada yada yada)  Everything used is of reputable brands like greddy, prp etc. My tuner did mention we’d keep the torque on the “lower” side.   glad to read that my engine won’t blow up on me lmao
    • It's a fuel pump. EFI, high pressure, but specs otherwise unknown. A bodge job.
    • 800 engine horsies is fine. Will need all the obvious upgrades. Rods, pistons, oil pump, big sump, sump breathing mods. Build for revs because revs are power with less stress on the bottom end compared to boost. Keep the torque down in the midrange, either by limiting boost or timing.
    • Hiya guys,    i’m currently in the process of getting my rb26 built. everything is being replaced with better/upgraded parts or oem when that’s good enough (which isn’t alot lol). someone earlier mentioned to me that i’ll be screwed cause the iron block can’t take 800hp (to the engine, not wheels) which is what it’s being built for.  what do you guys think about this, am I cooked or na? The guy building the engine will also do the mapping as he is “the guru of old nissan engines” here in Belgium. I know the mapping makes a huge deal so i’m not concerned about that.    I honestly he’s talking shit cause he’s that kinda guy but a second opinion never hurt anyone! cheers in advance! 🫶🏻
