It's real hard to find the correct fan clutch for RB20 and 25. I went through this a little while ago, although I had bought Dayco clutches and there is no cross reference between that one and the Davies Craig 5265 (which is odd, but forget about that for a moment).
Basically, the brand new Dayco ones would lock up at waaaay too low a temperature and so make a lot of noise, use a lot of fuel and slow the car down. Horrible. I ended up using a secondhand original RB25 clutch. If I was to buy a brand new one, I would definitely get a genuine one next time.
There's a lot of useless twaddle in my thread about the radiator. Ignore it. http://www.skylinesaustralia.com/forums/topic/418116-fan-clutch-shenanigans-any-clues/
Yeah genuine new Nissan clutches seem to be the only go. But at over $500 a pop, they are damn expensive.
Try Amayama; they are much more reasonably priced, if you can wait a week or so.
$201 is a much better price; add $30ish for delivery.
http://www.amayama.com/search/?q=2108252F00
the one for $201 is from the UAE, 20-30 days delivery
from japan $435 with 10 day wait.
I should've just got the standard one from Nissan at the start I guess.
ill give Nissan a ring and see how much they are. I will pay the money to get rid of that shocking noise.
the davies craig clutch is louder than my other 1.
cheers for your input guys!
I have found that is the "worst case scenario" on delivery time; they generally arrive quite quickly.
When you email for a price including shipping; they will also revise the lead time.
Give them a go; if all you are worried about is the noise (rather than imminent engine damage through overheating); why not wait & save a couple of hundred?
I guess you have a point there.
so the link you posted to before was the correct part number?
Sorry mate; that one is actually the SR20 fan clutch.
Below is a link for the R33 RB25det fan clutch.
http://www.amayama.com/search/?q=2108275T02
I would advise so you are 100% sure, that you go into the listings and confirm it for yourself.
This is the page I got to the fan price from; you can clearly see the make/model of the car, but check for yourself.
http://nissan.epc-data.com/skyline/er33/3933-rb25det/engine/210/21082/
thanks a lot for your help, ill get onto it today.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
