Car has started making epic squealing noises, and after an initial panic that it was turbo related, it looks like it's now alternator. Hopefully that proves right when I pull the belt off and check, but some basic tests show that it's most likely, and probably explains some battery deaths and other electrical issues.
I couldn't find a part number on here - surely someone has replaced an alternator on an M35? Anyone rebuilt one? Seems like bearings so we're tossing up rebuilding it and replacing the bearings depending on costs etc.
Everything in an alternator search seems to be RB... no VQ love.
https://www.sau.com.au/forums/topic/426890-m35-alternator/
Surely Scott isn't the only one that knows.
If 350Z belts are the same as NM35 belts, I guess that means the alternator is probably the same (well, it looks like the VQ35HRs had a different alternator to the VQ35DEs, bu you get my point).
Looks like 350Z units are available out of the US for $150-200, or high amp versions for $200+.
https://www.sau.com.au/forums/topic/426890-m35-alternator/#findComment-6887839
lol ok. He should have a couple.
Part number for VQ25DD and VQ35DE is 23100-CD010, Amayama have them for $507. Surely a VQ25DET would be the same as those two?
Fortunately it looks like its a standard Mitsubishi part, so bearings are available, part number 2312030R10 and 231200V017, Amayama flog them off for $25 or less per bearing (they want FIVE HUNDRED DORRAH for a complete alternator!).
https://www.sau.com.au/forums/topic/426890-m35-alternator/#findComment-6887868
I have one here if you need it mate, otherwise rip it apart and check the bearing numbers, they should be available at the local bearing supplier...
I would be cleaning up the slip rings on a lathe and replacing the brushes if you can find them.
https://www.sau.com.au/forums/topic/426890-m35-alternator/#findComment-6887900
Cheers mate. Dad's got a lathe so that should be fine. Not sure about brushes, might have to get a sparky to do that bit.
Sounds like there are a few 350Z owners in the states putting higher amperage units in for stereos etc. Not sure if that's worth doing at the same time, but seems like pulling it apart is going to be cheapest, easiest and quickest.
https://www.sau.com.au/forums/topic/426890-m35-alternator/#findComment-6887936
Cheers Cam. First things first I'll rip it off and see if I can rebuild it with new bearings.
Funny thing is P/N 23100-AM610 can be found online from a bunch of places. Only two hits for 23100-AL31A, one being this page.
If it's the same as the V35 and Pathfinder, why wouldn't it be the same as 350Z different p/n, so must be different, maybe higher amperage?
https://www.sau.com.au/forums/topic/426890-m35-alternator/#findComment-6889394
  • 2 years later...
  • 3 weeks later...
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
