Time for a quick bit of info on beer :)
All beers are made as ales or lagers; ale and lager are the two main branches (classifications) of the beer family tree and are closely related branches at that. Ales are the older, distinguished, traditional brews of the world, predating lagers by thousands of years, whereas lagers are a relatively modern creation, less than 200 years old.
The branch of the beer family tree — ale or lager — corresponds to the type of yeast used to ferment the beer. You have ale yeast and lager yeast, and these types of yeast, in turn, typically dictate the temperature at which the beer is fermented. Ales are traditionally fermented at warmer temperatures (12 to 21 degrees), while lagers are typically fermented at cooler temperatures (3 to 10 degrees).
The cooler fermentation and aging temperatures used with lager yeast slow down the yeast activity and require a longer maturation time. The cold environment inhibits the production of fruity aromas (called esters) and other fermentation byproducts common in ales. This process creates the lager’s cleaner taste. Long aging (or lagering) also acts to mellow the beer.
You can taste the difference, sometimes... Every beer beginner wants to know how ales taste different from lagers. If only it were that easy! This question is sort of like asking how red wines taste different from white wines (Ironically, you can find beer styles called red beer and white beer, but that’s another story altogether, and you can be sure that it doesn’t involve grape skins).
Ales share many common characteristics, and so do lagers, but the two groups overlap so much that any absolutes about either class are usually wrong. This overlap creates some confusion and the need for experts to explain the different characteristics, but it also creates the need for beer exploration.
You can say that ales generally:
- Include more robust-tasting beers
- Tend to be fruity and aromatic
- Include more bitter beers
- Have a pronounced, complex taste and aroma
- Are enjoyed warmer (around the 6 degree mark - don't get me started on beer temperature in Australia, we store, serve and drink our beer WAY too cold, but ales should be served warmer than lager. Ideally it should be around the 2-4 degree mark for lager and 5-7 degree mark for ale as opposed to the blisteringly cold -1 to 2 degrees most pubs operate at. The colder the beer, the more it numbs your palette and the less aromatics are released making a beer have significantly less taste. This is a good thing for generic malty lagers like XXXX and the ilk, as you don't really want to taste them anyway, but bad for any serious beer).
And you can say that lagers generally:
- Include lighter-tasting beers
- Tend to be highly carbonated or crisp
- Tend to be smooth and mellow
- Have a subtle, clean, balanced taste and aroma
So there you go, VERY brief beer intro :)
Seriously, around the 6 degree point beer begins to open up significantly. Most of the fermentation esters and aromatics are not released by the beer until it is at 5-6 degrees. Want to know why XXXX, Toohey's, VB etc get worse as they get warmer? Because it is low quality beer produced for a mass market. At REALLY cold temps (-1 to 2 like most taps pump out in bars/pubs) the aromatics are not released and your taste is numbed by the cold. It makes it considerably more palatable. Also, at lower temperatures carbonation does not happen as quickly and makes it go down more easily as well. Once these bulk beers warm up all the unpleasant aromatics and esters open up which significantly affects the beers taste and it becomes more active from a carbonation point of view which increases the rate that they are released.
It takes time, money and effort to brew these unpleasant characteristics out of a beer so the mass market brewers, who for most of the last century owned, or controlled through licensing, north of 85% of pubs (this only started changing in the 80's) tried to get the beer as cold as possible. Colder beer meant cheaper brewing which meant higher profits. A side effect was colder beer had less taste so became more appealing to a wider market.
So we're right to continue getting the beers off ice until the breweries start making it with better stuff...
I do have to say that I've got a bit of a soft spot for James Squire one fifty lashes at the moment. Can't seem to get enough lol.
The 150 lashes is a decent pale ale. If you like it coming off tap let it sit for a while to warm up slightly. The taste will get significantly better.
For really good beer in brisbane I'd reccomend Archive, Scratch and Platform as good bars to visit. These guys know beer and it is done right with brilliant seasonal selections, very knowledgeable staff, hand pumped ales (at Archive and Scratch at least) and well maintained and controlled reticulation equipment.
And for the record, I drink dark ales primarily. Dopplebock and porter are my favourites but as long as it is as black as my heart I am happy. Not a huge Guinness fan, mainly because too many places f**k up the beer line maintenance which really affects the taste of nitrogen charged beers.
Invented a drink its f**ked:
Iced t
Lime juice
Salted rim
Vanilla essence
Vodka
Drink it ATM... My minds exploding
I call it "The Abomination"
Also black sambuca and tomato juice (as mentioned by Bek lol)
I used to do a drink to f**k with people who were all "I don't know what I want, make me something bright and colourful" or some such crap.
I'd mix a shot of vodka with two shots of ouzo and 30ml of sugar syrup. I'd add a couple of drops of grenadine for colour and shake the ever loving shit out of it. It goes a pale, cloudy pink colour but tastes like a black jelly bean :) Really f**ks with people.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
