Did few more steps this morning, tried fitting up the 3/4 xspurts in stock neo rail and not happy with how far nozzle is away from the hole so i fitted the extensions with some washers for spacers..
post-70965-0-11410000-1449195021_thumb.jpgpost-70965-0-30731200-1449195048_thumb.jpgpost-70965-0-51262400-1449195063_thumb.jpg
Put the timing belt on with the two new RB30 tensioners ( double bearing) so should be nice and quiet.. aligned at close as it will go .post-70965-0-96537000-1449195145_thumb.jpgpost-70965-0-52089900-1449195163_thumb.jpgpost-70965-0-48940100-1449195194_thumb.jpg
Then lubed the top end and in the spark plug hole and turnt it by hand , bit of nervous moment lol.. was only slightly hard to turn as the rear lobes opened the valves but assuming thats normal, as a first time engine build , seeing how high the piston looks had me wondering if thats normal, pretty sure its fine though...
Edited by AngryRB
  • 3 weeks later...
It is still progressing, there's a number of hoses which im not sure where they go, if anyone has a link to R34 workshop manual that would be great, im not sure where the hoses go or come from for the air reg, might have to look at some engines at the wrecker's unless someone wants a 6pack for some help lol.... :thumbsup: here's some pics .. hoping my next post has the engine in the bay.. You can probably pick some of the hoses don't line up, i used some heater hoses off the R33 to join them to the block which also has smaller fittings, so got a couple of fitting made up to fit the larger R34 hoses to the RB30 fittings...
post-70965-0-72161000-1450863755_thumb.jpgpost-70965-0-20369300-1450863783_thumb.jpgpost-70965-0-09987600-1450863804_thumb.jpgpost-70965-0-93050200-1450863832_thumb.jpgpost-70965-0-07250800-1450863865_thumb.jpgpost-70965-0-75783500-1450863901_thumb.jpg
Just want to finish build for now, but am thinking either all carbon fibre look on the covers or a mix of carbon fibre and ceramic coating on rocker covers will look good on a silver car..
Edited by AngryRB
Progress.......
Got the RB25 flywheel, clutch and box on, i got excited a tiny bit excited to see NISMO on the flywheel but im assuming its just stock..
post-70965-0-18766800-1451298395_thumb.jpgpost-70965-0-01779400-1451298468_thumb.jpgpost-70965-0-45359800-1451298500_thumb.jpg
Then come putting the engine and box into the bay, turn't into a big job, needed some hemroid cream lol..
post-70965-0-06800400-1451298628_thumb.jpgpost-70965-0-54259900-1451298655_thumb.jpgpost-70965-0-98137700-1451298680_thumb.jpg
and finally in, looks like it sits pretty high, have to see if the bonnet will close tomorrow..
some underbody pics, can fit my hand under between the pan and power steering rack , so is some room to slot the mounts if needed..
And last shot of the turbo bolted on just for the hell of it..post-70965-0-72602300-1451298947_thumb.jpg
Edited by AngryRB
It's a GT3076 0.83rear, will have the gate on the housing... yeah i thought about high mounting it but the first setup i ever did with the stock mani felt the best so just replicating that setup to keep it simple.. :thumbsup:
With the height of this thing, it may look more mid mounted than low.. things have got tight spaced around the firewall and intake mani..
Can confirm the bonnet closes without issue so the RB30build thread was 100% correct about lowering the motor and thanks to other knowledgable guys suggesting slotting the mounts :thumbsup:
Progress come to holt while i gather funds for fabrication, planning a 4inch dump, plumbed back gate off housing, shortened intercooler pipe off throttle, 4inch intake pipe and tossing up on changes to the exhaust. Its currently 3 1/2inch with jap resonator which my money is on being a restriction , 100cell cat and an X-force 3 1/2inch muffler... couple of idea's are
- cut resonator out and keep rest the same
- cut resonator out and put the X force muffler in middle and a jap cannon with restrictor chopped out
I know the muffler on the end sounds more civilised but i want this thing to sound meaty so tempting to take option 2 , hmmm
I put car on ground today and made some lowering adjustment to try and get better stance, it had a 4wd look, any recommendations or input on people's R33 heights would be interesting to compare to get it sitting good but looks ok..
.post-70965-0-17087800-1452421415_thumb.jpgpost-70965-0-46557700-1452421442_thumb.jpg
I like having the 265's all around give's it a more pumped up look... cant wait to get this thing started...
Edited by AngryRB
  • Like 1
  • 1 month later...
not an update but after fitting the turbo on stock manifold, not real good having the a/c pipes so tight and close to a 3 1/2inch / 4inch dump plus external gate so im pricing up a top mount manifold and so far the sinco top mount is coming up the goods, so stay tuned for pics for a top mount and 3076 ... i think it will look a shit load sexy and give me far better value if i choose to go GT35 later and shoot for 400kw's... just saying.. :ninja:
also, i want this combo to sound raw rb and angry so top mount may help in this regard and having middle muffler with rear cannon, silencer removed for raw rb lumpy idle :)
also going to get a slim number plate to open up the front intercooler space, will need a mod plate with all mods too to relieve stress etc..
Edited by AngryRB
  • Like 1
I think the slim NPs are a good idea but a few blokes do not like them and have told me they look like crap ??
It gives you as much air intake as possible , cooler motor is a cool motor :yes: :yes:
Love the way some blokes sort of nail the plates, sometimes bent plates to a beautiful car, might have something to do with tracking ??? but it looks shit !
Guess beauty is in the eye of the beholder ?
Edited by Nismo 3.2ish
  • 4 weeks later...
Plate looks good pete, not sure where i'll mount mine yet but i want that intercooler area clear for the air flow and looks better too, small details though...
Exciting times ahead, ordered a sinco topmount manifold and just waiting for ceramic coating and delivery, then coat the turbo housing and see when my fabricator can get on the job.. got quite a few things for him to do , some overkill but will look sexy...
Also going to have a screamer pipe and possibly a HKS hi power 409, has silencer so i know its restrictive but will use screamer for anything drag/track related so should sound the goods :w00t:
Got the $$ now, waiting for shit to happen is frustrating but hope it will all be done in the next 6weeks..
Edited by AngryRB
No progress at moment, waiting for manifold and exhaust still, have sent turbo housings and rocker covers for ceramic coating so can't wait to see all these parts soon..
In other news, i acquired my brothers skyline so now i have two, i like this one more than my silver one so not sure what will happen here but i will convert to E85 and getting it dynoed, bout time i had some fun at a track or drags... Maybe start a different build thread for this one..
Edited by AngryRB
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
