I recently bought a rb25det neo engine from a importer and droped it in my r34 gtt that i bought with no engine, I started the engine last weekend and the engine runs well but on cold starts now it has trouble to idle and is real rough but then it straightens out after a bit and idles fine,
at roughly 1200-1500 rpm it misfires and backfires, I checked the ecu faults and its brining up code 21(ignition signal) and 34(knock sensor)
I have replaced spark plugs with ngk bkr6eya-11 and have cheched each idevidual coil pack with the car running and they seem to be working fine.
one of the plugs leading off the throttle body (in the picture) I dont have a plug on my loom to connect to it and im not sure what it is?
If anyone has any advice as to why it could be misfiring or what the plug is that would be great
https://www.sau.com.au/forums/topic/426954-r34-gtt-misfiring-and-backfiring/
I have followed the wires back and checked the loom but there is nothing there, I thought mabey the previous owner had cut it or something but cant find no other wire or plug that would go there.
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
