Unfortunately you can buy mobile network signal blockers online cheaply, so the thieves don't even have to be particularly sophisticated. :angry:
They're heaps good, but apparently really sophisticated thieves carry jammers with them that disable the GPS trackers, i've read it somewhere in these forums, and it makes sense. Doesn't hurt to have one hidden somewhere though
Edited by BuuBox
hey guys, a mate on mine found my car parked in Broadway shopping center on tuesday of last week, by complete coincidence.
i had a few people contact me that had seen this post and a few posts on facebook pages, they had witnessed an armed robbery that my car was used for.
i went to the carpark where my car was and called the cops, they towed it to an impound lot and investigated it, i then got it back last thursday.
it has some damage to the body and one wheel, but nothing to major, and mechanically it seems to be fine.
after talking to police i found out it had been used in several armed robberys around the city and was likely just dumped in the carpark.
i must be the luckyest guy out to ever even see this car again.
thanks for your concern and help, and it shows that putting it up all over the internet helped, i think social media did more in this case than police ever could have.
R32 GTR as a get away car?
They cant be that smart, the coppers will be chucking a u-turn every time they see it not because its stolen or has been used to knock off the servo but because its a Skyline.
Should of pinched a SS or something, lots of plates to steal and its common lol
Good to see you got it back though, a rarity these days
at the end of the day if they want it they will get it. but it didnt help that i had no alarm at all.
they would have thrashed it for sure, its a stolen gtr! but i am a mechanic and have sussed it out a fair bit, and seems to be running as normal, to tell you the truth i dont want to know the compressions, there isnt much you can do about it anyway, and my wallet isnt ready for a full rebuild at this stage.
Wow - very lucky. Glad to hear you got it back though.
I would also +1 - get it compression, leakdown tested and driven by some knowledgeable mechanics. Would be better to outlay a few $100s in tests to know the health of your car and how it's been mistreated.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
