Heys guys I own a 96 gts-t with an Rb26 transplant with the following mods:
Garret gt35R –700 horse and custom manifold, turbosmart ex-gate 42m
Wisco forgies
Shot peened and linished rods, arp bolts
Heads ported (JHH)
Tomei Cam gears
Halteck ek6-Halteck boost controller
Sard 700’s and Boshe o44
The car has made 386 horse (280 rkw) at 18 pound with the above set-up. From the quick research I have done the hks 2530’ s flow about 350 horse each as with the T517’s so our flow ratings turbo wise are similar 700 horse. After seeing what you guys are making I am left scratching my head as to what is wrong with my set-up. From the graph’s I have seen there is a 30 to 50 kilowatt difference….
My question is what the heck have I done wrong, and is there a big difference between states (I am in queensland) between dyno’s. Most of you guys who have seen or know of RNS11Z set-up and he made 420ish horsepower (I know it was a RB25) with a t88 and still wasn’t close to you guys, so what up.
Maybe my horsepower/kilowatt conversion is way off….any ideas? Also sydney kid what is you're formula for working out spool rates.
What is wrong with my set-up. From the graph’s I have seen there is a 30 to 50 kilowatt difference….
My question is what the heck have I done wrong..........
Hi help. let's start with dynos, the most popular is Dyno Dynamics with Shoot Out Mode software. If you are not using the same, then the comparisons are difficult to say the least.
386 rwhp is 288 rwkw using the usual "divide by 1.34" method.
I don't have a "formula" for working out spool rates, I just use experience on what we have seen in the real world. I can extrapolate that accross different engines and engine capacities. It is not perfect though.
As for what's wrong, let's start with exhaust, you didn't mention it? Intercooler? Pipework? Also I have a rule of thumb that says over 300 rwkw = upgraded camshafts, have you done them?
Without a graph of boost and A/F ratios, I am stuggling to suggest much else.
Sorry intercooler is a hks item all intercooler piping is hpc coated. As for exhaust it is an apexi gt item. I read a post about exhaust choking big horsepower car I think it was by "steve" so the thought did cross my mind was going to put the car on the dyno and drop the pipes to test the theory.
No I haven't done the cameshafts would rather spend the money on a three litre bottom end to be honest. Do they make that much difference for the expense.
Cams make a huge difference. Thats were i was losing most of my power. If your still using matty's dyno and making 380rwhp on his dyno, thats about 460 on other dyno's. His dyno is a fair wack out. It could also be your ecu that is holding you back due to no one being able to tune it.
I think your motor is being choked by the standard cams. No matter how much boost you run, the cams are going to dictate how much air is able to flow into and out of the engine (ok, that's pretty simplified, but that's the gist). You're going to need cams with a 3 liter bottom end anyway, so don't think of it as money wasted.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
