I currently drive a lighly modded Civic, but time has come to step up to a real driver's car. I'm looking at spending up to $23k on an R33 but I don't know where to start or what to look for. I am worried about not knowing the car's history, whether it has been thrashed, whether it has dodgy mods you can't see etc. I think I'd prefer to buy a totally standard car and mod it myself.
I need some advice before I jump in so I hope this forum can help. Where is the best place to buy and what should I be looking for? Apart from insurance, are there any pitfalls associated with owning a Skyline? Is it hard to get parts or repairs?
Any info would be greatly appreciated.
https://www.sau.com.au/forums/topic/4270-newbie-looking-for-r33-advice/
Go to Powerplay Imports
Thats where i got my car from and some others on this forum- also Mario got all his skylines from there
I have two bits of advice for you. If you are getting an R33 if money permits always go for a series 2 (1996) onwards, although these are normally $26K+ i noticed that GDZOOK , which is a nice white 1996 model is for sale for only $24900 or something like that or as much as Prank will hate this, his former car NOZILR is for sale at Unique for around $23K in standard form with a few extras.
If you want more info on the car at UAS pm me.... its available now.
Otherwise check out GDZOOKs ride in the for sale section.
Hope this helps
Nick
Series 2 are cosmeticly alot nicer.. interior, dual airbags, front lights, bumper, spoiler etc..
Sure the turbos arent as strong as the s1's, however they do spool up a heck of alot quicker, and still put the power to the ground when you need it :P
If its big power you want, you'll probably change the turbo anyway.. s2s are good for 12psi ive been told.. thats if your fuel system can handle it..
Ionos... the interior of the series 1s is nowhere near as nice as a series 2.......series two seats are better, refined dash, dual airbags, better headlights, generally more modern looking and yes the turbo is weaker when the boost is increased but if u want power turf the turbo for a better one anyhow!
Long and short. for the money being mentioned normally only a series 1 would be available and a pretty basic one at that..... i noted the options at the moment to pick up one of 2 1996 immaculate GTS-T's for around $24K.....bargain
Thanks for the help people.
Sounds like I'm better of spending a bit more on the comfy series II.
Are there any tell tale signs of past abuse I should look for when buying? Are there any mechanical differences in the different series apart from the turbos?
cheers
sciflyer: check for obvious signs of wear on seats, steering wheel, handbrake, gearknob, pedals etc.
Make sure you get any car you look at fully inspected by the NRMA and Revs checked.
Check service history also
Good luck, hope you find the car your after!
Don't write off the series 1 just yet. If I was buying mine again and could afford either, I'd still go for the series 1. Here's my reasoning in no particular order:
* Headlights. In my opinion the s1 lights look way better as they don't go flat along the top. GTRs kept the S1 look, even when the S2 was available, and they look damn good. I'm not sure if the s2 lights are brighter though, so that could be in its favour.
* Turbo. Stronger etc etc. Already mentioned above.
* Seats. Maybe I'm just weird, but I really prefer the s1 seats. Mine looks like it is brand new, so I'm probably biased because of this.
I agree with the others on the body kit bits. The stock S2 kit looks a lot nicer. My car always had a 400R front bar and GTR wing, so it didn't affect me. Besides a stock kit is pretty rare anyway. I reckon it's HARDER to find a stock example.
Just my opinion anyway ;)
Cheers,
Michael
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
