hi there, i have a "00 rsfour stagea with the rb25NEO and i am trying to figure out wether i've blown my piston rings or turbo.
i've searched but havent been able to find anything about this so if theres a thread about this please just send me a link or tell me where to look.
now, i was driving along the freeway at around 130km/h and doing a few pulls and playing around with the gears and spooling the turbo up as it's my first turbo car and had only driven it from where i bought it so far. as i pulled of the freeway and stopped at an intersection without any warning the car just starts blowing smoke and ran rough as anything and just felt like it was stalling and starting up again so i limped it downhill to a carpark and shut it off. when i started it i held the revs around 3,000rpm and it blew smoke like crazy but didnt feel like it was misfiring at all, but as soon as the revs dropped below 2,500rpm it would completely drop like it was stalling and starting again and i couldnt bring the revs back up.
i have the turbo off and just played around with it and there is a bit of play in the shaft and when i spin the the blades i can see oil coming down the blades from inside the turbo.
so i really need help with this before i fork out money for a turbo or rings.
any help is appreciated
https://www.sau.com.au/forums/topic/427036-rb25neo-blown-turbo/
you guys don't think if he did a seal in the turbo it would put the oil into the air and into the cylinders/plugs and it would smoke and run rough? My R33 did the smoke/run like a pig thing when my fuel pump shat itself and it leaned out and destroyed the ring lands on the pistons(amongst other things) but that was white smoke, what colour smoke was yours?
cheers guys for the other ideas, havent even looked at the cooler yet, but when i took the turbo out one of the cooler pipes had oil all around it. and my fuel was on empty pretty much so i could've done something to the pump
also it was blue smoke pouring out the exhaust
yea had the cooler pipe off for a while and cleaned it up when i did. but all through the cold side and into the throttle body there was a fair bit of oil so im hoping its the turbo, if it was seals the oil would be on the echaust side of the turbo and not through the intake? that make sense or am i just rambling like the rb noob i am? :P
Is there bucket loads of oil or just residue?
Your blowby vents back into the intake on stock cars and does cause the whole intake to look rather grubby over time.
If you were mopping a litlre of oil out of the cooler pipes i would plug up the oil feed and return to the turbo and do a comp test to make sure the engine is ok. If its only a whole stack of gunk stuck to the sides of the pipework i would put my cash on it being a turbo.
How wet is the turbine wheel of the turbo? is it soaked with oil?
turbine was clean but i also didnt get the turbo off for a few days but just spinning it in my hand i had oil coming down the blades. and it looks pretty gumky but not litres at all. it didnt drip out of the pipes or anything.
im gonna try get a new turbo first get that back together then do a comp test as im getting a bit lost with all the parts in my garage.
I would say you just blew a cooler hose off somewhere
Cause if the turbo blew an oil seal it wouldn't idle rough but just blow smoke and if the turbine wheel was dry wont be a turbo seal as oil won't dry up
And a light film of oil in the intake of the turbo is normal blow by
i think the smoke was caused by the turbo seal (just going with the general advice i've been getting). not saying your wrong by any means because im not really in a position to doubt anybody haha. comp test definately if it keeps smoking up im just really hoping it is the turbo
Come on guys really? It would never blow blue smoke unless there is OIL IN THE COMBUSTION CHAMBER........ A blown cooler pipe will NOT cause oil to pour into the cylinders, only a few things could cause the problem stated and judging by the description it sounds like a blown piston, however u start with the cheap stuff,
Pull out the plugs first, look at the condition of the plugs, if the are covered in oil it will confirm you have oil getting into the engine before the intake manifold, if only one or two plugs are covered n oil then it an internal issue localised to those cylinders. If you hav an exploded plug then its lookin bad for the motor, Next do a compression test, if all cylinders come up good its more likely to be turbo or valve stem seals, start with those simple checks then let us kno what results you get
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
