For Sale: 2002 Nissan Y34 Gloria Granturismo Ultima
Engine: VQ30DET - 3L Turbo.
Gearbox: Automatic 4 Speed - Tiptronic
Kms: 59,000
Interior: Immaculate condition, ALL electronics work flawlessly, No strange noises or vibrations.
Black Seats Interior
Black/Silver Trimmings
Dual Zone Climate control.
Steering Wheel Controls.
Electronic Seats with Memory Function.
TV Screen with Audio Inputs.
This vehicle has ALOT of features, Way to many for me to mention, to name a few of the fancy features you have the ability for the Window to go Up/Down when you get in/out of the car, The rear demister can automatically come on, The interior lights will point to which door opens, The cup holder can fit 2 styles, The on dash display screen can alert you for Speeding, It also has a Maintenance plan built in and a history of your fuel usage displayed on screen.
Exterior: Black Exterior with full Aero kit consisting of side skirts, front lip and rear bar extension.
V35 GT 18" Premium white wheels on near new tyres
Nismo Spring + Shocks - Amazing ride not noticeable to really be aftermarket but makes the car sit a little lower.
Motorized self closing boot.
Info: Build date of 12/2002, Always serviced engine every 4-5,000km which includes filter swap.. Gearbox+ Diff Oil Change & Plugs + Coolants + AirCon Maintenance were serviced about 10,000km ago in preparation for Summer!
Amazing car to drive, very comfortable and smooth, Log book serviced.
Never a problem what so ever, Other than the wheels and the lowered suspension the vehicle is standard and hasn't been touched.
The car was optioned with its higher model Triptronic gearbox.
Very low Km as i live close to work and i have another car also, Have owned the car for close to 1year now and a full tank lasts me 2weeks which is about 700kms or so.
Vehicle will come with a RWC, up to buyer in the end, Will come with all paper work and previous RWC certificate, Nothing to hide inspections welcome.
It is very hard to find a car featuring the whole selection of Black on Black on Black(Black Exterior, Black Seats, Black/Silver trimmings) when normally you would find the White Exterior on Grey Seats on Wood Grain trimmings, This car is the highest quality you could get before upgrading to Leather, And it cost me alot of money to find such a match!
Anti Scratch plastics are still on all chrome pieces on the floor also!
Reason for Sale: Due to working so close to home, and due to family reasons i have another car at home and am currently in the midst of purchasing a house i have opt'd to down grade.
Interstate purchase is not a problem i have had cars go interstate before so that can be organized along with all transfer papers that are required.
Swaps are not a problem, not to fussy on cars.. Due to my local amount of driving im steering towards just a normal car so Holden/Fords aren't out of the equation!
Cost: $13,750 NEG
Contact: Antonio - 0-4-2-1 9-2-7 2-5-0 or PM.
FOR PICTURES PLEASE CHECK CARSALES ALSO - http://www.carsales.com.au/private/details/Nissan-Gloria-2003/SSE-AD-1055256/?Cr=1
https://www.sau.com.au/forums/topic/427046-nissan-hy34-gloria/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
