So, as the topic suggests, I recently had a 19 inch 265/30 tyre with approx 4000 km of driving suffer a collapsed inner sidewall. The manufacturer says it was due to under inflation. I normally run around 34psi and have been told it should be 40psi. I've run that pressure for years with no trouble. What do you guys reckon? Discuss..
https://www.sau.com.au/forums/topic/427051-tyre-pressure/
I have always ran 32-34 psi in my tyres. Even on the track day I ran 32 psi to cope with the extra heat.If I put 40psi in tyres it seems to harsh of a ride. I've never had a blow out but I have seen tyres on other cars start to get big bubbles in the side wall before. I think it was a defect in the tyre that I saw.
I told one of the owners to take it back to where she got it from and they basically said the same thing it didn't have the right pressure.
It seems to be a cop out from the tyre retailers.
Is it possible to get a leak past the rim with hard take offs and cause the tyre to go down quick and blow it out?
Waits for derderpumkin to put his 1c worth into this thread.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6891776
34PSI sounds incredibly low to me - what you'd expect on a 185/60R14 or something.
When I get new tyres fitted, I always ask the staff what pressures to put in. Typically the lower the sidewall, the higher the pressures they're recommending. 40PSI sounds pretty normal for a 265/30 to me.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6891783
I have run same pressure on an 18 inch 265/40 on my old GTR for 6 years including 7 or 8 track days etc and never had any issue. If 40 psi is suggested and I run 34 that means its around 85% inflated. Is it reasonable to say that 15% under inflation will cause tyre failure??
I reckon thats a bit of a cop out. I was never instructed anything regarding pressure when getting these tyres. Surely they should come with a warning at point of purchase if this is so?
Anyway the tyre company has replaced the failed tyre but be careful guys!
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6892258
The only time I've dropped the pressure to 34 was for a drag day once. Straight after that I've pump it back up to 38. I find 40 a bit too high personally and typically just run 38. 35-36 will give a slightly better grip but for daily driving 38 is good enough for me. 265/35/18 Michelin PS2.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6893107
I used to run 34psi in my 225;50;16 on my R32GTR but was told to low , told 40-44psi was better suited to my car .tyres were
K102 hankooks
Dunlop sp sport fast response
both above size and never had any problems like blow outs etc
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894439
I run a 235/45/17 and the tyre shop guys recommend it be on 34psi. I normally bump it up to about 38-40 as I find this is gives me a better ride. Never had any issues at all.
If the manufacturer is saying that the issue is caused by under inflation than to me that is a massive cop out.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894836
That would be my thoughts.... Unless it was running 20-30psi or something way out of spec!
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894841
Interestingly when I checked my rear 265/35/18 tyre pressures at Caltex Bolivar on the way to Kadina they were 44psi - I even commented on this to others there. I had them fitted around 2 months ago and had not checked them since.
Bizarrely the front 235/45/18s that were fitted by the same shop at the same time were 28 and 32psi - weird.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6896361
yea i run the same as krishy. :action-smiley-069:
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6896804
I run around 40-42 psi on my 18s depending on how the tyre is wearing. I would class 34 as under inflated on a tyre with such a small sidewall. The smaller the sidewall the higher the pressure you need. Roughly speaking, if you have half the sidewall with the same amount of flex it will get twice as hot.
It is also a good idea to check your pressures regularly, particularly after you have new tyres fitted. You will find that in the first 500km or so they will drop pressure as they bed in. I have had tyres drop 10 psi in the first week and then not drop again for 10,000k
Edited by Race__24
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6897826
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
