So, as the topic suggests, I recently had a 19 inch 265/30 tyre with approx 4000 km of driving suffer a collapsed inner sidewall. The manufacturer says it was due to under inflation. I normally run around 34psi and have been told it should be 40psi. I've run that pressure for years with no trouble. What do you guys reckon? Discuss..
https://www.sau.com.au/forums/topic/427051-tyre-pressure/
I have always ran 32-34 psi in my tyres. Even on the track day I ran 32 psi to cope with the extra heat.If I put 40psi in tyres it seems to harsh of a ride. I've never had a blow out but I have seen tyres on other cars start to get big bubbles in the side wall before. I think it was a defect in the tyre that I saw.
I told one of the owners to take it back to where she got it from and they basically said the same thing it didn't have the right pressure.
It seems to be a cop out from the tyre retailers.
Is it possible to get a leak past the rim with hard take offs and cause the tyre to go down quick and blow it out?
Waits for derderpumkin to put his 1c worth into this thread.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6891776
34PSI sounds incredibly low to me - what you'd expect on a 185/60R14 or something.
When I get new tyres fitted, I always ask the staff what pressures to put in. Typically the lower the sidewall, the higher the pressures they're recommending. 40PSI sounds pretty normal for a 265/30 to me.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6891783
I have run same pressure on an 18 inch 265/40 on my old GTR for 6 years including 7 or 8 track days etc and never had any issue. If 40 psi is suggested and I run 34 that means its around 85% inflated. Is it reasonable to say that 15% under inflation will cause tyre failure??
I reckon thats a bit of a cop out. I was never instructed anything regarding pressure when getting these tyres. Surely they should come with a warning at point of purchase if this is so?
Anyway the tyre company has replaced the failed tyre but be careful guys!
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6892258
The only time I've dropped the pressure to 34 was for a drag day once. Straight after that I've pump it back up to 38. I find 40 a bit too high personally and typically just run 38. 35-36 will give a slightly better grip but for daily driving 38 is good enough for me. 265/35/18 Michelin PS2.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6893107
I used to run 34psi in my 225;50;16 on my R32GTR but was told to low , told 40-44psi was better suited to my car .tyres were
K102 hankooks
Dunlop sp sport fast response
both above size and never had any problems like blow outs etc
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894439
I run a 235/45/17 and the tyre shop guys recommend it be on 34psi. I normally bump it up to about 38-40 as I find this is gives me a better ride. Never had any issues at all.
If the manufacturer is saying that the issue is caused by under inflation than to me that is a massive cop out.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894836
That would be my thoughts.... Unless it was running 20-30psi or something way out of spec!
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6894841
Interestingly when I checked my rear 265/35/18 tyre pressures at Caltex Bolivar on the way to Kadina they were 44psi - I even commented on this to others there. I had them fitted around 2 months ago and had not checked them since.
Bizarrely the front 235/45/18s that were fitted by the same shop at the same time were 28 and 32psi - weird.
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6896361
yea i run the same as krishy. :action-smiley-069:
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6896804
I run around 40-42 psi on my 18s depending on how the tyre is wearing. I would class 34 as under inflated on a tyre with such a small sidewall. The smaller the sidewall the higher the pressure you need. Roughly speaking, if you have half the sidewall with the same amount of flex it will get twice as hot.
It is also a good idea to check your pressures regularly, particularly after you have new tyres fitted. You will find that in the first 500km or so they will drop pressure as they bed in. I have had tyres drop 10 psi in the first week and then not drop again for 10,000k
Edited by Race__24
https://www.sau.com.au/forums/topic/427051-tyre-pressure/#findComment-6897826
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
