Hey guys I have done a man conversion in my car and I put a r34 turbo on while the motor was out all is good but today I tried to give the big girl a bit more boost and up to 0.5 bar was all it would take builds that fast and holds no lroblems but nothing more I know the turbosmart boost tee was working as it came from my working car set to 9psi
I have looked over it all and am kinda scratching my head any suggestions before I rip the turbo off ?
https://www.sau.com.au/forums/topic/427069-boost-issue-wont-go-over-05-bar/
I wouldn't start pointing the finger at the turbo..well just yet at least, sounds more like a incorrect signal connection somewhere (vacuum lines).
Try this (will give you an answer straight up), hook up an aftermarket boost gauge, disconnect your vac line going towards you're actuator completely, go for a spin, put your foot down and KEEP YOUR EYE ON THE BOOST GAUGE and back off straight away if it passes 7psi to prevent blowing the turbo!!!!, if it boosts past 0.5bar(7psi), then you have a faulty boost controller!, if it still won't boost past 0.5bar with vac line disconnected, then you have some serious exhaust back pressure issue, possibly blocked cat, or you may have a leak somewhere in the system i.e, cracked pipes, blown gaskets, damaged intercooler, etc.
I got carried away and pointed said finger.... swaped it for the one that was running with that valve on 9psi got to .6 bar thats it I swapped the cooler as well incase it was leaking same deal so I think it may be the bleed vavle or something else it cant be exhaust as its a straight system no cat
I didnt even think to try the disconnect vacum off thr gate ill try that see what happens cheers :)
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
