Thinking of parting with my current R32 GTST.
White
R32 GTR wheels
Toyo T1R tires
Apexi lowered springs (unsure of shocks)
Re-upholstered stock steering wheel
Nizmo gear knob
New shifter and hand brake leather boots
Pioneer deck with AUX
sunroof (tilt and slide, no leaks or cracks)
Fancy alarm and immobiliser
GTR cooler
Gibson motorsport R31 style intercooler piping with HKS SSQV replica bov (same sound)
Pod filter
bleed valve
Split dump pipe and full 3 inch exhaust (very quite)
New radiator (stock size)
fairly new clutch
slotted discs
R33 GTST Series 1 RB25det using stock RB25det ecu.
Car and engine have around 175k kms.
Working air con.
Working power windows and mirrors.
Non bubbled dash
All air con vents intact (well passenger side round one is gone and a boost gauge sits in it's place)
HID lights and LED parkers
LED dash lights.
About to get new oil and filter this weekend.
Rego till November 2013
RWC will be supplied
The bad:
Small spot rust bubble on roof (smaller than 10c piece) and some paint flake and marks on front bar.
basically, this car is awesome sauce.
And I'm kind of attached to it but will no longer have a need for it and would like someone else to enjoy it.
Price wise, I'm thinking around $8900
If there is interest I will take some pics.
Willing to sell for cash or swap for $8900 cash.
Up to you.
BUY IT NOW before I'm forced to go to boost cruising.
https://www.sau.com.au/forums/topic/427078-qld-89-r32-gtst-with-rb25det/
  • 3 weeks later...
  • 1 month later...
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
