As part of my upgrade I'm installing a single large fuel pump rather than 2 pumps in parallel.
Most aftermarket ECUs can output a PWM signal based on selected parameters (eg injector duty, rpm, manifold pressure etc).
My question is what is used to switch off and on the pump? I see Motec has a purpose built dual half bridge amplifier for such a duty.
http://www.motec.com.au/dhb/dhboverview/
This is only rated at 20A continuous which may be inadequate for this pump at full speed.
Can a solid state relay be used or will this not be up to the task of switching at many times per second that the PWM signal will request?
Cheers
Gav
http://aeromotiveinc.com/products-page/accessories-electronics/16306-billet-fuel-pump-speed-controller/
Pricey but rated to 40A.
What pump are you using and whats the maximum current draw.
Fuelab pumps have built in PWM contollers. They just require a 500 - 1500Hz input.
Thanks Kitto - these are quite crude and only have a high/low switch point. I think they also require an old style tach signal from the coil.
I'm using an Aeromotive Eliminator pump - not sure of the maximum draw.
Surely someone here must have set up a PWM output to control a fuel pump .
Thanks Simon
I have one of the Eliminator Stealth kits on the way which will let me easily construct a "pump in surge tank" setup similar to the Sard tank I had previously.
After speaking with more people it seems that a simple high quality SSR will do the trick.
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
