Did a search but came up with nothing, so has anyone made their stock 34Gtt plenum forward facing by blanking the original entry point and making a new throttle body mounting plate on the front? Would this actually work or be bad in regards to flow? would like to get rid of the excess pipework across the front of the engine, along then across the engine to the throttle body and the aftermarket FF plenums sound like a P.I.T.A gettting the AAC and everything else connected and working.
Fors and against please guys, and if anyone has done it pictures please.
Because the standard plenum was designed (by some very clever Nissan engineers) to have the air enter from the side and distribute it evenly to all 6 cylinders. That is not a trival exercise, given the shape that the plenum is. You can bet your last buck that there's some rather clever design ideas hiding inside there. It's not just a box.
Chop and change it the way you describe, and despite the people out there who have done it and therefore have a vested interest in defending the results (so they don't look stupid) or are actually ignorant of the results (poor air distribution), what you will inevitably do is wreck the distribution between cylinders. The box was designed to receive air from the side, now it's getting it jammed in from one end, and the box has NONE of the design features that you'd expect to see in an end-fed plenum.
Ok, that's sort of what i was thinking but wanted confirmation. So my only real choice is to fork out heaps of $$ for a FFp and new throttle body and the dramas that come with fitting one i am guessing.
  • Like 1
dunno what GTS kid just said but look at the GTR, those clever little engineers at Nissan designed the forward facing plenum and that didn't cause "uneven air distribution" as he described.
I agree don't chop it tho, leave it or get a good greddy copy instead
Seriously, are you just following GTS around trying to flame him? No relavance to GTR plenum, his comment was regarding forward facing the stock Gtt plenum.
This is the epitome of retarded. Yes, you are correct, Nissan did design a forward facing plenum and yes it does work. But he is quite obviously talking about the RB25 inlet plenum, as is everybody else because that is what the thread is about. He is talking about the uneven air distribution that is created when you convert a standard RB25 side feed (for lack of a better name) plenum to a forward facing one. He is not talking about a the RB26 plenum which was DESGINED to be forward facing.
Using your logic converting the RB26 plenum to side feed would not have any "uneven air distribution"
Anyway, to OP, yes you are better off leaving the standard inlet plenum as it is or puchasing a greddy/plazmaman etc one. As has been stated a standard converted plenum often leans out cylinder 6. Using a forward facing plenum you get power loss in the low/midrange.
Edited by iruvyouskyrine
Why not? You can run a cooler pipe Gibson style from the drivers side over the top of the cam covers.
Cheers Wolverine I will google/search Gibson style, is it similar to gangnam style? :P
Thanks for the input guys.
He is not talking about a the RB26 plenum was was DESGINED to be forward facing.
Um if u look at the RB26 plenum, the 1st 3 cylinders get the majority of the air according to GTS boys theory because its forward facing, but this isn't true. All the cylinders do get even airflow despite the forward intake being closest to the 1st 3 cylinders.
Anyway it was a silly idea by OP, i wouldn't mess around with plenums, get an aftermarket one if that's what u wish
You are totally missing the point and comparing apples to oranges. It has even air distribution because it was DESIGNED, i repeat, DESIGNED to be forward facing, unlike a modified standard plenum that was DESIGNED to be side-feed and has been modified to be forward facing, hence having uneven air distribution. If you cannot understand this, then i truly feel sorry for you.
Sorry OP, as i said before your only real options are
- Standard plenum
- Std plenum with different crossover piping as shown by Wolverine
- Plazamama/Greddy forward facing plenum
If you already have a NIStune or aftermarket ECU, and are willing to give up traction and cruise control then you can use an RB25DET Series 2 Throttle body, and it will work fine with your car. The standard 25 Throttle body is exactly the same as the one in the post wolverine made, and will allow you to run that crossover piping no worries :)
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
