I don't know how many of you skyline nuts would know this , But the 2.8 Turbo diesel Patrol shares the same bottom end and gearbox and bolts directly onto the engine mounts and straight into the box , And my 2.8 has 250,000 on the clock and runs 16 psi of boost and a diesel chip , and they generally don't last that long . So i'm thinking of chucking a NEO into the Troll . Can you guy's help my out with a fuel pump , injectors , turbo , Ecu and so fourth. I'm looking to make 300 - 350 ponies on 33's and 2.2 Tons of truck , who can help me? And approx pricing?
https://www.sau.com.au/forums/topic/427161-rb25det-neo-in-something-else-d/
I see this is your very first post on SAU - welcome.
You will be quickly advised to search the forum.
Here's a helping hand to discussion on the same subject:
http://www.skylinesaustralia.com/forums/topic/418647-choosing-the-right-engine/?hl=+rd28
You want a 30 bottom end, you do.
The extra capacity will be well worth it in a 2 ton plus rig.
Even with the low gearing etc, i would have to agree here!
25/30 for you!
If you had to engineer it I'd do an RB30ET to get the numbers right , actually I think pov pak GQ STs had an RB30S (NA carby) std .
Anyway with an RB30ET you get to have an Australian legal engine option - and then if one morning you woke up and found it'd grown a twin cam head in the night - whos to know ? Engine number stays the same .
You're talking about a truck thats 800 Kg more than a 1400 kg R33 Skyline so every low down Nm of torque is a god send
A .
So obviously I'm a noob to this skyline stuff (God forbid I drive a 2012 lancer daily :0 ) , so does the 30 bottom end just bolt straight into the 25's head ? But I keep all the top end accessorys from the 25 ?
Not exactly that easy! There is a whole section dedicated to that topic i believe! If its not something you are familiar with i dont recommend you have a go!
I've helped mates with multiple engine swaps , from blown 3.0Ls to 4.2s , rb30 carby into an rb30 from a Vl with the turbo , up to 6.0L Vortects into a shorty patrol , I have the mechanical no how , just not the Rb series knowledge hah.
Its not likely to be a straight swap, that is what i meant :)
Ye hah :D , the Rb series seems so swap and play honestly it's ridiculous , but honestly I think I'll keep it simple honestly , all rb25 neo , but a bigger fuel pump and injectors and turbo when it needs it , 90% of my 4wding is sand dunes honestly , we don't have any steep rock tracks or anything hah. Limiter bashing up dunes at night time in a huge sand bowl with 20 cars is about it ;)
RB's do not like prolonged limiter bashing :P
Aww :( only on special occasions then! Do you know what turbo would be ideal for 300 horses and early spool? And what size injectors?
Oh dear... This has been covered SO many times that i dont know what answer to give you lol...
High flow and a set of 1000s cheapies will do it!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
