Hi all,
As hard as it is putting this ad up, the time has come to sell my dream car. Only selling due to leaving my current job & very soon to be moving back to NSW before heading overseas. I need it sold soon, hence the price corresponding with K's & modifications.
$41,500
This is the ultimate street & circuit GTR built with only the best parts available & maintained to the highest standard.
HKS TOMEI NISMO etc no ebay or non-genuine parts have ever been used. The car has had upwards of $85,000 spent on it.
Never driven in the rain!
The car has had another 12months rego put on (valid till 21-5-14) & now a Road worthy Cert ready to go.
The car has modifications plates for: Aftermarket seats, aftermarket breaks, Roll cage (at the end of april this year, you can now NOT get a street car mod plate certified for a cage. But this is already done so its good to go. Its also mod plated & rego'd as a 2 seater.
The car has been freshly tuned only a few weeks ago & made over 500hp at all 4 wheels on a low, safe & very reliable 18psi.
And like it always has, is running like a dream.
All work and tuning is carried out by GT Auto Garage.
As you can see with the road worthy done, rego, mod plates etc this is a hassle free buy.
Serious enquiries only!
NO low ballers, swaps or time wasters
Test drive will only be available after deposit is taken.
Don't let this GTR pass you by! Im happy for inspections as this car in the flesh is second to none!
Mods list consists of the following.
3/1995 SERIES 1 BCNR33 GTR V-SPEC
ENGINE
Extensive porting and machining of the head
Modified exhaust ports (enlarged)
Modified intake and throttle bodies (enlarged).
Hks camshafts
Inlet 272deg with 10.5mm lift
Exhaust 280deg with 10.5mm lift
Hks adjustable cam gears
Hks timing belt
Hks valve springs
Hks retainers
1mm oversized Tomei valves
Tomei head gasket
Tomei head studs
Tomei exhaust manifold gasket (steel)
Tomei enlarged throttlebody gasket (steel)
Head flowed and tested
Rocker covers/front timing cover painted Nissan pulsar metalic blue
R34 GTR n1 emblum on centre cover
Nismo oil pump
N1 water pump
Nismo N1 pistons
Nismo N1 rods with 21mm gudgen pins
Standard Bcnr33 GTR crank (wanted to keep it 2.6l)
Nismo bearings, big ends/mains
Nismo sump baffle
Arc oil catch tank
EXHAUST & TURBOS
Brand new Trust/Greedy T-517z 10cm twin turbo kit.
R34 N1 Gtr match ported exhaust manifolds
R34 N1 Gtr match ported dump pipes
HKS stainless Front pipes
HKS Silent Hi-Power 3.5inch stainless exhaust with no cat. (not so silent exhaust)
INTAKE
2x z32 airflow meters
Tomei z32 airflow meter plug adaptors.(Standard airflow meter plugs still attached so wiring harness hasn't been modified)
Apexi twin air intake pods
Hks hpc coated air intake pipes
Hks silicone hoses
Hks clamps polished
DRIVELINE
R33 GTR series 3,5 speed gearbox (freshly rebuilt)
C's short shifter (rare & you cant buy these anymore) The best GTR quick shift on the market.
Brand new Jim Berry race twin plate clutch (sprung centre)
Factory rear V-spec diff.Fluid has been changed and the electronic diff performes at its optimum
Nismo 1 way front lsd
Standard diff gears remain 4.11.
FUEL
Sard 800cc injectors
Nismo larger intake pump
Nismo fuel pressure regulator
COOLING
Hks R34 GTR 105mm intercooler (brand new costs $1757)
Hks hpc coated polished intercooler pipes with Hks silicone hoses & polished clamps
F-win Japanese 3 core 52mm alloy racing radiator (new $1,700)
F-win Japanese radiator air deflector plate
Nismo thermostat
Samco top & bottom radiator hoses
Hks remote oil filter relocator with extended braided lines.
Hks oil cooler.Oil cooler located on passanger side behind the front indicator (on front bar) Screw out the indicator and bracket when circuit racing as it allows more air flow. Modified the wiring to the indicator so it can detach easily.
Also attached a water squirter on the front of the oil cooler so when on track days just give a quick squirt and temps drop down by as much as 10-12deg.
You pull back the wiper stalk and the cold water or ice you place into the water washer bottle squirts a large mist over the oil cooler.Simple but effective!
Also modified the inner guard (plastic) to allow the hot air from the oil cooler to vent out.
INSTURMENTS/ELECTRONICS/ECU
Nismo 320klm dash
Nismo centre gauges
Defi oil preasure gauge (black face)
Defi oil temp gauge (black face)
Defi water temp gauge (black face)
Defi controll box with peak & memory.
Gauges located where the centre ac vents are on the console for ease of vision and keeps it legal.
Hks evc-s boost controller with 2 memory settings.I have the first setting at 1.1bar & the second setting at 1.3bar (about 18psi)
Hks turbo timer
Apexi power fc with hand controller
Split fire coilpacks
Hks racing spark plugs
Brand new factory nissan injector harness
SUSPENSION/WHEELS/TYRES
Hks hypermax PRO circuit coilovers,height & damper adjustable.I have had these re-valved and softer springs fitted for our roads & tracks as the Jap settings are way to hard.
Cusco adjustable upper controll arms
Cusco adjustable front caster arms
Cusco adjustable rear camber arms
Cusco adjustable rear tow arms
Cusco front strut brace
Cusco rear strut brace
Moonface (japanese) sub frame bushes
Moonface diff mounts
Hks Kansi under body bracing
Nismo circuit link sway bars front & rear
Wheel allignment settings are-3.5deg front camber,7deg front castor,2deg camber on the rear,zero toe on rear.
Wheels were Volk TE37s but is being sold as is with GR6's, 18x10 +15
Tyres are new Toyo Proxes T1R 275x35x18 (can fit 295x35x18 for track days)
BODY
Genuine Top secret carbon time attack bonnet (painted white) ($2800)
Aero catch bonnet pins (folding flush type)
Carbon ganador mirrors ($690)
Nismo clear side indicators
Nismo 400r clear front indicators
Nismo carbon piller garnish
Nismo carbon rear wing end caps
Nismo factory option rear spats
Series 3 GTR front N1 bar with nismo intercooler ducts
Series 3 GTR front lip (35mm lower than series 1-2) costs $1420
Series 3 GTR xennon headlights with optional xennon high beam very rare and cost me $3600 from nissan Japan
Auto select genuine carbon front canards
Eurou aero parts production front under defuser (Japanese)
Custom made brake ducts (alloy with black powdercoating) drops temps down by 15deg
Empier Aero Top secret carbon fibre rear diffuser
Carbon fibre GTR wing blade
BRAKES
R33 GTR Brembos front and rear
Project MU 2 piece slotted rotors (front)
Project mu club racer pads rated to 800deg (front)
Project MU rear slotted rotors
Project MU break shims
ferodo ds 2500 rear brake pads rated to 700deg
Adr approved braided brake lines front and rear
INTERIOR
Standard front & rear door cards (immaculate condition)
Recaro limited edition SR7 front seats
Nardi deep corn suede 360mm steering wheel
Pioneer stereo fitted
Aircondition system still fitted
ITEMS I HAVE REMOVED FOR WEIGHT SAVING
Rear parcel shelf
Rear speakers
Rear wiper & wiper motor
Boot carpet
Rear seats
Some sound deading. (saved around 25kg).
I have these parts in a box if you wish to re fit them.
Only HKS synthetic oils have been used.
The car is in imaculate condition and there are no loose ends with it, everything works like it should!.
I dont want to sell it and had planned to keep it for life but my personal circumstances have changed very quickly and im leaving my job (currently in the Army) and moving back to Newcastle NSW where ill be there for a short time before i venture off overseas.
there is no money owing on this car and all that needs to be done is drive it.
Its never been driven in the rain by or previous owner.
Only driven once in a blue moon and even then, only to keep cob webs out.
Countless hours have been spent modifying it and all the parts were new and only Japanese and genuine parts were used.
If genuinely interested,
Please contact me (dan) on 0423544543
Located in Brisbane
I'm sure I've left a bunch of things out.
But I can assure you, you will not find a better presented R33GTR v-spec in such good condition.
For pics please go to my carsales ad:
http://www.carsales.com.au/private/details/NISSAN-SKYLINE-14829066
If that link doesn't work, just go to carsales , select: Nissan, skyline, Queensland, colour-white, $41,500 .. It's had NIZ033 plates on it.
I'd put pics on here but I just don't know how haha!
Need to sell soon, so please call me if u are interested! I just want it to go to a good home/enthusiast.
I need it sold by mid July, make an offer or tell your friends! Confident when I say, this is one of the best r33 GTRs in the country!
Wow, nice car mate... Good luck with the sale!
So clean, hosted some pics off your link.... hope it helps! -
I can vouch for this car, I have spent hours upon hours with it, I have never seen an r33 like it.
The quality throughout the whole car is phenomenal, from the dry carbon canards, genuine rear diffuser, how tight the car is to drive, I could go on all day.
Need to sell!!!
I'm giving it away at this price!
Don't buy a car that's gonna cost u 5-10k or even more down the road!
Get this and enjoy all the brand new gear! No money to spend, all u can do is change set ups if u choose!
Surely someone is interested?
Also included the car has just been window tinted (20% tint and with anti-glare) about 2months ago with a life time warranty, 1kg fire extinguisher, standard mirrors & wing blade that will also come with sale, genuine nismo gear knob, D1 Spec wheel nuts, space saver wheel, brand new battery.
There's most likely a lot of other things I've forgotten too.
Someone get on this! You'll only make money on it!
Edited by henson
Price drop - $38,500
Giving it away at this price and its hurting!
This will not disappoint and it's a deal you won't beat!
Anyone?
Edited by henson
Gee, what a bargain, this car is awesome value for money, if I was buying a GTR at the moment, this would be a no brainer. My 34 is up for sale in the next few months, will be a very sad day for me, I can tell you.
Good luck with sale mate, don't drop the price anymore, someone will come along who appreciates your car.
If I still had that sort of cash lying around to blow, I'd jump on this in a heartbeat. Without-a-doubt the best 33 I've ever seen. (And i've owned, and seen many). I usually don't post these "nice car" posts in for sale adds, but this has to be an exception. What a beauty! Best of luck dude, Don't budge too much on your price. It's worth it.
  • Like 1
Thanks for the kind words guys! Appreciate it!
And yeah, literally only offering that price on here as I want a passionate enthusiast to have the chance to own this car.. It's flawless!
Just need to have ONE person who is legitimately in the market for a GTR to actually come and inspect it and take a look to see what they are getting first hand, and I know she'll be sold in a heart beat!
Still haven't had one person follow through on coming to see the car.. It's spinning me out lol, if they knew the bargain they were getting gahhhhh
God I wish I didn't have to sell her!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
