I have taken my rb26 out of my car not because of any problems whith it but I wanted to detale the engine and engine bay. When I brought the car I was told it had bean rebilt recentley whith forged pistions ect. I nead to get boath hot and cold sides gaskits so i was wondering would it be a good idea to take the head off too and just check everything inside while the engine is out. Please excuse my bad spelling I allready know i carnt spell well. Thanks Mark
https://www.sau.com.au/forums/topic/427182-engine-is-out-what-shoud-i-do-to-it/
Check all hoses under the plenum and around the back. Replace if not nice and new looking. Check timing belt, same there. Look at front and rear seals. Fit uprated balancer if the mood (and available $$) strikes you - This is an opportunity to allow for a crank trigger if you feel the need may come at a later time.
You could look at how clean and well sealed the throttle shafts are. These suck badly when they leak (pun intended).
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
