And yes I have used the search button & have just fin trolling through 68 pages of stagea brakes.....First I have a 4/97 S1 wgnc34 & wish to replace front disc rotors & are having troubles finding correct ones!... The specs I have are:
Outer dia- 280mm
Thickness- 28mm
Height-53.7mm
Ctr bore- 68mm
PCD- 114.3mm
  1. Are these correct?
  2. Will a later model fit eg..290/296mm outer dia with my original calliper?
  3. What brands & or serial no's
  4. What is the "height" measurement referring to in the specs?
  5. I have e-mailed RDA & they only have specs for a 2001 (RDA 954d) which has a outer dia of 296mm will these fit? Has any on tried these on a 4/97 S1?
Any help with this prob will be appreciated.
Thanks in advance Shane.
https://www.sau.com.au/forums/topic/427208-disc-brake-specs-for-s1/
Ok, I have just phoned GSL Ralley Sports (very helpfull i might add) it seems S1 are a trick beast to match up. They suggest to actually measure my current disc & get back to them & they will try & sort something out. Prob is it will be too dark by the time i get home to get measurements (see from my first post) can anyone help me with some measurements or serial numbers as I need new rotors fairly urgently.....Cheers
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
